Keeping the engine cooler
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Oct 3, 2016.
  1. Taxi/Limo
    Taxi/Limo Active Member
    524
    107
    Hello All
    I noticed my 2010 Prius III not Three runs from 70 to 90 Celsius
    Is that normal?
    Would it be a good idea to try to get it to run a little cooler?
    If so how can one do that ?
    Thanks
    Nexus 6 ?
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    The thermostat in my 2012 Prius v is set for 195F which is 90C, so when it gets to 90C in the engine coolant flows to the radiator.
    For it to stay above 90C for any length of time the radiator would have to be inadequate to cool the engine.
    Stant
    I am not sure why you would ever want to change this, but you could go to your dealer and buy a lower temperature thermostat.
  3. bisco
    52,399
    have you considered freezing bottles of water, and storing them in the engine bay?this works quite well for cooling the battery.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Maybe this thread will get over 100 posts on how to lower temps 1 or 2 degrees just like those frozen bottles :).
    But we might get there with double posting though(y).
    Manhal K Alrashdan and bisco like this.
  5. StarCaller
    StarCaller Senior Member
    1,279
    730
    Cedar Crest, NM, USA
    good luck with finding a lower temp thermostat for a generation 3....
  6. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Assuming all cooling parts on your 2010 are OEM, or have been replaced with equivalent parts that will operate at the same parameters as the OEM parts, your car will operate as it was programmed for maximum efficiency. So, NO. Leave the car be, and just drive it.
    The car is programed to operate at maximum efficiency based on various inputs from:
    engine/coolant temperature, AC or Heater demand, Gas Pedal input (mild, moderate, heavy gas pedal depression), etc.
    As someone pointed out, changing the thermostat to a lower or higher degree thermostat, will affect the engine operating temperature, which will have an impact on your efficiency.
    Manhal K Alrashdan likes this.
  7. Toppcat
    Toppcat Member
    223
    69
    Northern California
    90 c is Normal operational temperature! Unless you can rewrite new map programs for the ecm. Then try drill out bleeder hole in the thermostats this will allow more flow! Drain entire coolant system engine block too! Refill with distilled water and redline metal wetter! If your planning to run engine for long periods of high rpm s like 5000 + should see a 10-20 degress reduction engine temp. You can also have the radiator customize adding a extra row of veins. Cutting out bigger opening for the radiator to allow more air flow, air scoops too!
    Robert Holt likes this.
  8. BruceInOKC
    BruceInOKC Member
    190
    Oklahoma City, OK
    No, it's not a good idea to run cooler than the designed operating temperature. If your engine runs cooler, it's less efficient, which lowers your mileage. If your engine runs cooler, it increases the water and fuel condensation in your oil, which increases engine wear.
  9. Taxi/Limo
    524
    107
    okay
    I was under the impression a cooler running engine would last longer
  10. RRxing
    RRxing Senior Member
    2,554
    1,828
    NEPA
    Just the opposite. A fully warmed-up engine is at its most efficient. As far as the engine lasting longer if running cooler - a BIG maybe - but not worth the loss in efficiency and not worth the cost of any modifications. 70-90C is perfectly normal. Let the car run as designed.
  11. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    Yes - I believe the Beatles wrote a song about this subject LOL
  12. Taxi/Limo
    524
    107
    Beatles so what about reducing friction ? Any oil or oil additives I can use?
    Nexus 6 ?
    Raytheeagle likes this.
  13. Mendel Leisk
    41,923
    Just ensure it's 0W20, and don't overfill.
    You're monitoring engine temp with something, ScanGuage, or a phone app? Anyway, the 70C to 90C temps you're seeing is very similar to us. A regular car will get up to 90C and stay there, perfectly normal. The Prius, for various reasons, and especially in winter, tends to run cooler.
  14. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Next oil change I am going to put in BG products MOA. I use 5W-30 synthetic currently with a oil change every 10k mile interval. Did the BG Products EPR cleaning last oil change and the oil came out jet black, so some deposits were removed.
    This change will be MOA then the following change will be the extended life MOA.
    Going the controlled experimentation route to gauge performance;).
    Rebound likes this.
  15. Taxi/Limo
    524
    107
    BH Moa?
    Nexus 6 ?
  16. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Yup.
    Google BG Products and you'll get to Motor Oil Additive (MOA). Some interesting stuff and good videos if you have time:).
    It will add cost to an oil change, but if you DIY, it is cost neutral or positive when compared to dealer oil changes;).
    The EPR helped smooth out the idle, made the fresh oil look cleaner on the dip stock and reduced oil consumption in my case. I have also used the 44K fuel cleaner.
  17. Robert Holt
    Robert Holt Senior Member
    1,313
    889
    +1 to NOT changing the thermostat or attempting to make it run cooler than 90 Celsius, 195 Fahrenheit .
    In fact, many posts in in PriusChat involve blocking parts of the front air intake to help the engine warm up more quickly to the standard operating temperature . Since I have installed movable grill blocks , I use a Scangauge to track engine temperature and have found that the blocking lets the ICE get to 195 more quickly on cold mornings. Watching the mpg estimates vs engine temps, FWIW, I also observe that the mpg estimates when the engine is warming up to that operating temperature are noticeably less than when the engine has reached its normal operating temp.
  18. Kenny94945
    Kenny94945 Active Member
    858
    433
    Sausalito
    2016 Prius v wagon
    I leave to the experts, but can add this:
    a) Make sure there are no leaves blocking the radiator fins.
    b) Make sure grill and lower diffuser/ air vent directors are A-O-K.
    c) Make sure radiator coolant is fresh/ tests within specs.
    I'd assume the OEM system is just fine for most areas.
    Siberia/ snow belts and Saudi Arabia/ desert could have different specs...again I'll leave to the experts.
    Toppcat likes this.
  19. Toppcat
    Toppcat Member
    223
    69
    Northern California
    I don't recommend addtive to synthetic oil each manufacturer has its own blend to deliver it's design performance! adding foreign chemicals changes the chemical structure .
  20. Jimi1976
    242
    124
    Denver, CO
    What makes you think regular synthetic oil is not working?
    Toppcat and Mendel Leisk like this.
  21. Taxi/Limo
    524
    107
    I suppose it is but I believe I have seen Royal Purple do a better job than mobile 1 in reducing friction on youtube
    Nexus 6 ?
  22. Jimi1976
    242
    124
    Denver, CO
    Then try the royal purple.
    Worst case : you just spent twice as much on oil for no reason.
    Best case: it lubricates the motor. Motor doesn't blow up.
    #20 Jimi1976, Nov 8, 2016
