Engine removal diy advice is it possible?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by drewbabich, Jun 27, 2016.
  1. drewbabich
    drewbabich Junior Member
    68
    Sorry if this has been posted before I couldn't find it.
    My 2010 Prius needs a new engine. My mechanic will do it for 1000 but I'd like to do it if possible. Biggest job I've done is head gaskets before.
    I've done a little research and looks like disconnecting the electricity and jacking the car up high enough to drop the engine below is important.
    Can u do this job without a lift?
    Is there any tutorial with pictures of the job online?
    Do you need special tools?
    Thanks
    kc5dlo likes this.
  2. JC91006
    JC91006 Senior Member
    16,765
    8,563
    Yes you can do it without a lift, but much easier with one. What state are you in? I know some mechanic will do it for less, it's not that hard. It's just heavy.
  3. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
  4. tankyuong
    1,555
    661
    Central MO
    engine removal is done from front with bumper and radiator removed
  5. RRxing
    RRxing Senior Member
    2,545
    1,821
    NEPA
    None of the links work but here's what's involved...
    fopoku2k2 likes this.
  6. bisco
    51,851
    i'm throwing up the white flag.
  7. Rivetjoint
    Rivetjoint Junior Member
    New Jersey
    A word of caution. I recently had the engine on my 2011 (302,000 miles) replaced due to head gasket issues and the high mileage. Had a 2014 engine installed (49,000 miles) by the dealer. The tech had some difficulty in removal and in the process fractured the windshield. Of course they ate that little item. They mentioned that the windshield extends into the engine compartment a bit and was bumped during the lift out. (At least that's what they told me.) Best of luck.
  8. Mendel Leisk
    41,347
    Step 36: "Disconnect Engine Room Main Wire", and of course: no picture. Toyota has no idea how to write a shop manual. :mad:
  9. bisco
    51,851
    engine room? as in down below?:cool:
  10. Mendel Leisk
    41,347
    Step 29: remove "NO 2 CYLINDER HEAD COVER". That's this, lol:
    makbg1 likes this.
  11. CR94
    CR94 Senior Member
    2,689
    1,169
    Northwestern S.C.
    Where's No 1 Cylinder Head Cover?
  12. bisco
    51,851
    don't worry about it, you can leave it on.
  13. Paul Schenck
    Paul Schenck Active Member
    523
    306
    Fresno, California
    I did it myself last week, with a 2x4, straps, plywood, welding rods,4 jackstands and hydrolic 2ton jack. <3
    makbg1 likes this.
  14. ChapmanF
    18,100
    All this "Toyota has no idea how to write a shop manual" when every blue infobn.png button in a TIS manual is a link that takes you straight to a whole fahrvergnügen illustrated procedure for completing that step??
    -Chap
  15. Mendel Leisk
    41,347
    Links don't work in my back alley copy. :oops:
    m.wynn likes this.
  16. Paul Schenck
    523
    306
    Fresno, California
    I used a Haines manual and yes the $300+ I spent on the factory manuals did not return my investment
    iPhone ?
    kc5dlo likes this.
  17. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    u are a prius SAVIOUR. thanks for the post
  18. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    any advice for me whilst i do my swap this week??
    Paul Schenck likes this.
  19. RRxing
    2,545
    1,821
    NEPA
    Mine came from TIS as individual .mht files, so the "links" didn't, and I have a life to live instead of making them all work.
  20. ChapmanF
    18,100
    When you're viewing the manuals on TIS, the links all just work, you don't need to do anything to make them. On days when I'm really feeling like I've got a life to live and just want to solve my problem fast (like yesterday, when I was baffled by the C1451-from-hell), I just feed them $15 and solve my issue and move on to fun things.
    I agree there are plenty of good reasons to hang on to local copies and refer to them later, even if the links get lost in the process. I just figure it might not be quite fair to Toyota to grumble how they have no idea how to write a manual, just because it's harder to use when the links have been lost. :)
    -Chap
