Prius 2 ECO - Low Tire Pressure?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by fsu23phd, Oct 6, 2016.
  1. fsu23phd
    fsu23phd Active Member
    186
    114
    Wilmington, NC
    Hey folks, apologies if this is already discussed, I am in a hurry.
    I pulled into my parking space this morning and the tire pressure light was on. I had just enough time to check all of the tires, they were all around 32.5. This doesn't seem that low to me, as this pressure would have been perfect for my old 2010 Prius.
    The door says to keep them between 36 and 39.
    I have the 2016 2 ECO with the bridgstone LRR tires.
    Do I need to get air in the tires before I drive home?
    I live 2.5 hours from home, with a good mix of highway (I'll drive about 79 MPH) and small town driving. I stayed in a hotel last night and did not drive the 2.5 hours this morning, just about 5 minutes.
    The tempature did drop about 10-15 degrees as hurricane matthew bears down (I am in eastern north carolina, about to drive to Wilmington).
    Thanks!
  2. Mendel Leisk
    41,780
    Was your pressure check at the end of an extended drive then? The tires will be hotter, reading higher pressure than they would if cold, anywhere between 3~5 pounds. A drop in ambient temperature will drop their pressure a bit too. I would bump them up, say at the nearest gas station after work.
  3. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Low pressures tend to flex and heat the sidewalls more, which can weaken them, this also heats and expands the air in the tyre, which increases the pressure, sometimes to over inflation, these events can lead to a blowout. Not a risk I'd take at 79 mph on a highway. Get them pumped up before the long haul.
    FuelMiser and RCO like this.
  4. Dragon Rider
    Dragon Rider Active Member
    344
    212
    Miami
    This happen to me today. I have at the front 39 psi rear 36 psi . Don't know what happen . I put air in all tires and the tire pressure signal it gone now .I was reading the tiredrack booklet it said u can lose air on the tire even if it does not have a flat.
  5. Mendel Leisk
    41,780
    When we were on road trip vacation the TPMS warning come on. Freaked, I pulled into a gas station and checked pressures; they all were fine. I raised them all about 4 pounds and the light went out. Later lowered them to normal: the light did not return. In other words, weird.
    RCO likes this.
  6. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I wonder if atmospheric pressure affects the sensor, were you at a different altitude on your trip ?
    RCO likes this.
  7. Mendel Leisk
    41,780
    No, near sea level, about the usual. West Coast of Vancouver Island, Long Beach area. Nice country btw. :)
    RCO likes this.
  8. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    OK Mendel, perhaps because the atmospheric pressure is higher at sea level than at the top of a mountain and would tend to squeeze the pressure inside the tyre such that the difference between the two triggered the sensor.
  9. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Thinking the car was initially set with the pressure in the 40's by the factory, the dealer didn't check the pressure, now they are 10 pounds or more less than when set, so the alarm went off.
    If you reset the cars pressure gauge (computer) the light will go off and you can drive, when you put them back at a higher pressure, reset the computer.
    RCO likes this.
