Tanabe Lowering Springs for 2016 Prius
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Jorlan, Oct 1, 2016.
  1. Jorlan
    Jorlan Junior Member
    35
    27
    I just want to ask if anyone has the Tanabe Lowering Springs on their 2016 Prius...I Have the Model Two and I recently just replace the 15" Wheels to the 17" Touring ones, added the Side Splitters and a rear spoiler lip...I guess you can say I have a Model Two Touring LOL...
    But I want to give it a more better stance so I was going for the lowering springs...But does it still give the same suspension feel or it actually feels more sportier?
  2. krmcg
    2,592
    2,392
    Whittier, CA
    Yes I do. Sportier with flatter turns.
    RCO likes this.
  3. roadwarrior28
    roadwarrior28 Member
    68
    69
    Portland, OR
    Three Touring
    Do you notice any difference in ride quality? How about bottoming out?
  4. krmcg
    2,592
    2,392
    Whittier, CA
    I have to be slow and careful going up driveways. Some scraping does occur. Ride quality is enhanced.
    roadwarrior28 likes this.
  5. RCO
    RCO Senior Member
    3,709
    5,186
    Cornwall
    When you say enhanced, improved in what way please?
  6. krmcg
    2,592
    2,392
    Whittier, CA
    Smoother. Less body sway. Feels like the car is "held down" at higher speeds.
  7. RCO
    RCO Senior Member
    3,709
    5,186
    Cornwall
    Aaah! Thanks for that. Not sure I'll bother myself tho.
    krmcg likes this.
  8. RCE1
    RCE1 Member
    70
    71
    Northern California
    Four Touring
    I don't think I'd want the car to be much lower.
    RCO likes this.
  9. keithrash
    keithrash New Member
    honolulu
    Did you install springs yourself?
    Wondering how hard it is...
  10. krmcg
    2,592
    2,392
    Whittier, CA
    No. It was done by Tanabe. (mine was the first US 2016 Prius and needed to be fit checked)
  11. keithrash
    honolulu
    Cool!
    I think i'll try 16 or 17" rim/tires and see how it looks.
    I'll install the springs if necessary...
  12. galownia
    galownia Previous master neon mechanic
    117
    73
    If you have basic mechanical skills, springs aren't "hard" but you need to have the right tools, and realize that compressing springs to remove the strut tops can be dangerous. If your tool lets go, it, or the spring, or strut top, or all, can go flying all over the place causing damage or injury.
    Also, you need to align your car after lowering. Your camber and toe will likely be affected. Make sure you know the torque specs for the struts, the strut top, etc.
  13. keithrash
    honolulu
    Thanks for the heads up!
    I do have the tools and spring compressor to do the job.
    I've installed lowering springs and coilovers on Toyotas, Scions and Audis in the past.
    I'm reluctant to install springs on my 2 week old prius thinking about the new warranty.
    I did install coilovers on my Audi when it was still under warranty, but I had it for a couple years before installing.
    I'll still try 17's first...and see if I'm satisfied with the "looks"....
    I had a 2014 Lexus CT200h F-Sport prior to this Prius, so I'm hoping to get this Prius to look decent at the least!
    hahaha
    galownia likes this.
  14. Zwergo
    Zwergo New Member
    herford
    2018 Prius
    Weiß jemanden ob es mitlerweile Tieferlegungsfedern für den gen4 gibt die ich in Deutschland eingetragen
    Weiß jemand ob es schon ist
    Tieferlegungsfedern für das Gen4 sind diejenigen, die ich in Deutschland registriert habe
  15. steuermann
    steuermann Junior Member
    near Hamburg/Germany
    2018 Prius
    Isch nischt schprechen auslaendisch Alter eh!
  16. Zwergo
    Zwergo New Member
    herford
    2018 Prius
    [QUOTE = "Steuermann, Beitrag: 2678926, Mitglied: 161572"] Isch nischt sprechen auslaendisch Alter eh! [/ QUOTE]
    Ich habe es mit Übersetzer versucht.
    Ich suche für meinen Prius IV Tieferlegunsfedern die ich in Deutschland eingetragen bekomme. Also mit Gutachten .
  17. Zwergo
    Zwergo New Member
    herford
    2018 Prius
    Ich suche niedrige Federn für meine ZVW5, die auf deutschen Straßen verfügbar sind. wichtig ist mit guten Gewissen für deutschen Tüv
