charging hybrid battery
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Dimkaps54, Oct 15, 2016.
  1. Dimkaps54
    Dimkaps54 New Member
    Greece
    Hello , I am trying to find a charger for hybrid battery without car modifications. I can open the battery and charge the cells. Do u have any chargers to suggest ? thank you in advance
  2. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    If you are asking about your 2005 Prius, the range would be so limited that it would not be worth the effort. The car really only used about a third of the capacity range in order to extend the battery life.
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,422
    3,294
    Madison, Wisconsin
    There is a charger available in the PriusChat store.
    If you don't want to buy it through there I can sell you the same one directly.
    Feel free to call me with any questions.
    I'm happy to help.
  4. Dimkaps54
    Greece
    I am running a garage , i want to fix many batteries mostly of prius and lexus cars
  5. ericbecky
    4,422
    3,294
    Madison, Wisconsin
    Does your shop work on the Gen 1 Prius? (2000—2003)
    Where are you located?
  6. Dimkaps54
    Greece
    Mostly 2005-2008 but we try to fix any generation because batteries arent that different we are located in Greece .
