Prius cell throw code cell block becomes weak
Discussion in 'Gen 2 Prius Technical Discussion' started by Parrish21r, Oct 21, 2016.
  1. Parrish21r
    Parrish21r Junior Member
    43
    36301 Dothan Alabama
    On techstream when the car is running it's throwing code for cell block 2 becomes weak. Yesterday I finally identified which cell was acting unusual and replaced both cells in cell block 2 with cells from a 2014 prius that I got new. I balanced everything before test driving and when I get on the gas at about 31 mph the triangle comes on and when I decrease speed down til the motor cuts off the triangle comes on. Any ideas?
  2. jadziasman
    jadziasman Prius owner emeritus
    1,355
    486
    District 6
    The 2014 modules might not be a good match to your old 2006 modules. Did you scan for DTCs yet? That's
    the first thing I would do.
  3. Parrish21r
    43
  4. jadziasman
    1,355
    486
    District 6
    Are you certain you replaced the correct modules? Block 2 is on the passenger side of the battery. Some have
    made the mistake of replacing Block 13 (which is near the battery ECU on the driver's side) instead.
    #4 jadziasman, Oct 21, 2016
  5. strawbrad
    strawbrad http://minnesotahybridbatteries.com
    953
    993
    Check your engine oil.
    Really!
    Low oil will slosh around on acceleration and deceleration. This will cause the triangle to go on and off.
    Brad
  6. Jmack111
    Jmack111 Member
    370
    78
    Tacoma wa
