Installing rear view camera - question
Discussion in 'Gen 3 Prius Accessories and Modifications' started by txl146, Oct 24, 2016.
  1. txl146
    txl146 Member
    301
    NY
    I just received rear view camera and mirror from Amazon. Total came out to around $150 for the kit.
    Where would be the best place to wire 12V and ground wires for the mirror on 2011 Prius? I plan to install them this week and perhaps take some pictures along the way if anyone's interested. I plan to tap rear view camera wire to reverse light.
    Thanks!
    #1 txl146, Oct 24, 2016
  2. txl146
    txl146 Member
    301
    NY
    I searched and think found the answers I needed finally. Thank you.
    Dylan Doxey likes this.
  3. txl146
    txl146 Member
    301
    NY
    Has anyone found a way to install rear camera without drilling a hole on hatch?
  4. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,455
    92
    Ideally it will work something like this.
    If your aftermarket camera doesn't mount this way, then you'll probably need to get creative.
  5. SilverSexBullet
    SilverSexBullet Junior Member
    Cincinnati
    I installed mine Friday night. I just had to drill a 5/16" hole on the plastic piece that snaps into the hatch. The hardest part of the whole install was removing that piece. If I was you I really wouldn't stress about drilling that hole, its super simple, plus if you did screw up that is probably like a $.50 piece from the dealer.
  6. txl146
    txl146 Member
    301
    NY
    Thanks - how did you manage to run RCA cable through rubber piece? I found the hardest part was to run wire through it...
    Also, do I need to connect rear view mirror power cable to IGN or cigarette lighter on fuse box?
    #6 txl146, Nov 6, 2016
  7. Dylan Doxey
    1,389
    3,455
    92
    My installation was exactly like this video.
    At 2:00 minutes in it shows the business about stuffing through the rubber boot. I don't think you should need to be stuffing an RCA plug through the boot.
  8. txl146
    txl146 Member
    301
    NY
    Thanks... where did you connect ground wire from rear view camera? Since rear hatch is made of plastic I don't think I can connect ground wire there.
