Fog Lights Installed and Working 4 Non Touring
Discussion in 'Gen 4 Prius Accessories and Modifications' started by lohikaarme, Oct 22, 2016.
  1. lohikaarme
    lohikaarme Active Member
    337
    338
    NY
    2023 Prius
    Limited AWD-e
    All fine and dandy except for the little issue of the engine harness doesn't have anywhere to plug into
  2. sttkailua
    sttkailua Active Member
    190
    151
    Hawaii
    priusfan,
    A few of us are buying OEM fog lights from a US dealer.
    Harness need to be after market or put together by scratch.
    Thanks,
    stt
  3. alexgrigori
    alexgrigori Active Member
    163
    109
    Technology
    From aerodynamic point of view I think this fog light compartment is poorly designed.
    IMO it would be beneficial to put a plastic 'canopy' over this area to allow air passing freely around.
    Should no fog light used I'd make an air passage connecting this 'dead zone' to the front tire area.
  4. Dragon Rider
    Dragon Rider Active Member
    344
    212
    Miami
  5. sttkailua
    190
    151
    Hawaii
    dragon,
    Look at Toyota online parts, in Virginia.
    It should fit your blank fog light area.
    stt
    Dragon Rider likes this.
  6. ChapmanF
    18,257
    Oddly enough, Toyota's own design in Gen 3 was that the factory foglight relay is in the instrument-panel relay box, so the wire through the firewall carries the full foglight current. No idea why they came up with that, but they did. Even funnier, in Gen 3, even cars without fogs have the relay, and the fuse, in place, but no wire. Run that wire (through the firewall grommet, ugh, PITA) and everything works.
    It sounds from your Gen 4 info as if they at least stopped including the relay when you don't have foglights. Does your info show where you're supposed to plug the factory relay in? Did they move it to the engine compartment relay box, or does it still go in the instrument panel one?
    -Chap
    Robert Holt likes this.
  7. lohikaarme
    337
    338
    NY
    2023 Prius
    Limited AWD-e
    I was supposed to receive my 87a relays today but they didnt arrive. Here are pictures of the harness i made (missing the relay). I installed this harness and tested jumping the 12v to the power wires of the fog and drl to make sure it all worked. as soon as the relays arrive it will all be finished.
    pjm877 and sttkailua like this.
  8. sttkailua
    190
    151
    Hawaii
    lohikaarme,
    I thought that you would have completed yours before I finish mine!
    I have all my parts now, and will try to turn on the switch this weekend.
    I will post my efforts, if I am successful.
    stt
  9. lohikaarme
    337
    338
    NY
    2023 Prius
    Limited AWD-e
    I had it all wired but i opted to take the suggestion to put in relays and build. More professional harness
  10. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Looks good, similar to the harness I made for my HID dual relay setup:
  11. thewraith
    thewraith Junior Member
    67
    DC Metro
    I will post an update when my "alibaba" prius fogs arrive.
  12. lohikaarme
    337
    338
    NY
    2023 Prius
    Limited AWD-e
    Relays arrived, all working, full control- they power is killed when the car acc is turned off. No I dont have it set in such a way where I can activate both fog and drl at the same time.
    Mattheww, pjm877, thewraith and 4 others like this.
  13. sttkailua
    190
    151
    Hawaii
    DonD and Dragon Rider like this.
  14. randomwalk101
    randomwalk101 DYI'er
    532
    271
    texas
    Dragon Rider and sttkailua like this.
  15. sttkailua
    190
    151
    Hawaii
    random,
    Price is good now, you can install for under $300!
    Might be the same as the one that mark27lim installed.
    The yellow color is the LED element. The light would be bright white.
    It seems more visible than the OEM lights.
    stt
  16. randomwalk101
    532
    271
    texas
    sst
    It does looks like lights are both white and yellow. Look at all the pictures and compare. I think it's a mod from oem
  17. sttkailua
    190
    151
    Hawaii
    well,
    You may be correct, buy it and confirm!;)
    All installation steps have been done for you!(y)
    stt
  18. krmcg
    2,592
    2,392
    Whittier, CA
    From the eBay seller
    BLITZ XW50 likes this.
  19. sttkailua
    190
    151
    Hawaii
    random,
    I did go on eBay to look at these Chinese fog lights.
    There are 4 wires to the light vs 3 for the OEM Toyota light.
    The pictures show:
    1. All lights on - all white
    2. Bottom 3 lights on - white or amber
    3. Top light on - white
    So, would there be a 4-way switch? 2-2 way switch?
    krmcg posted a wiring diagram, but it was too blurry to read.
    stt
    #39 sttkailua, Nov 13, 2016
  20. thewraith
    67
    DC Metro
    I got those same chinese ones for $200 shipped at alibaba express. Took 2 weeks to come in.
