Unused blue plug inside front doors
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Brandon10, Oct 16, 2016.
  1. Brandon10
    Brandon10 New Member
    Morgantown
    Hey guys. Just had the inside panels of my Prius off yesterday and noticed a blue female plug connected to wires that isn't used for anything. I've attached (I believe I have) an image that I took of the inside of the front passenger door. Does anyone know what these plugs can be/are used for?
    51,899
    welcome! must be an option you don't have on the two. 3 door sks?
  3. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    Things that come to mind:
    *Open/close windows.
    *lock/unlock doors.
    *Power mirror adjustment.
    Have you checked to see if it ever has power?
  4. ChapmanF
    18,154
    Somebody else had a similar question recently, I mean it was about a completely different connector and in a Gen 4, but I gave a pretty complete step-by-step on how to look that up if you want the right answer.
    Otherwise, the thing that happens in a forum thread (as you can see in that other one) is people will fling out various random answers. :) Two of the guesses on that thread were actually right, but even those two people didn't give any more information on why they thought so than other people did who guessed wrong—and one of the right guesses was followed by another poster saying it couldn't possibly be that. :)
    Look it up and you get it right every time. :)
    -Chap
  5. bisco
    51,899
    october 16th, 17, 18, 19, 20, 21, 22, 23, 24th...
  6. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
  7. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    If it were the rear door, could be. But that's a front door; the rear has a white connector for the non-existent tweeter in the lower models that points straight up.
    Edit: SKS is probably right. My Two has that empty blue connector on the passenger door, but it's connected to another plug on the driver's.
