Brake, ABS, VSC, (!) lights all on after locksmith programmed new key
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by zackgemmell, Oct 25, 2016.
  1. zackgemmell
    zackgemmell New Member
    San Diego
    I took my car to the local locksmith and they programmed a new key fob for my 2006 Prius and when I started the car I noticed the brake, abs, vsc, and (!) lights were all on. I drove it around to see if they would turn off and noticed that the brakes felt different and not as responsive as they used to be. The new key has full functionality but I'm wondering if the programming may have corrupted something along the way.
    Does anyone have any experience with this problem? Any help is appreciated.
    Thank you,
    Zack
  2. JC91006
    JC91006 Senior Member
    16,827
    8,600
    There shouldn't be anything inn the key programming that would do that.
    There is an extended warranty on the brake actuator pump on the prius. That may be the failure
    SM-N900P ?
  3. zackgemmell
    San Diego
    Thanks JC91006,
    I will look into that. It just seems like too much of a coincidence that this happened immediately after the new key was programmed, but you never know.
  4. JC91006
    16,827
    8,600
    A bad actuator will feel like you don't have power brakes, it's actually quite dangerous if that's the case
    SM-N900P ?
  5. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    Reboot the car by disconnecting the 12v for 10 seconds
  6. JC91006
    16,827
    8,600
    But if the locksmith screwed up using a computer attached to the car, it could affect the other electronic systems in the car
    SM-N900P ?
  7. zackgemmell
    San Diego
    It definitely feels like I don't have power brakes anymore. I'll try the reboot as well.
    Thanks
  8. RobertK
    RobertK Member
    128
    Norfolk, VA
    Check the age and voltage of the 12V battery in addition to rebooting the car. The locksmith may have run down the battery while programming the new fob, and a bad 12V battery can cause a lot of problems.
