Prius Prime Acceleration
Discussion in 'Prime Main Forum (2017-2022)' started by Prashanta, Oct 21, 2016.
  1. Prashanta
    Prashanta Active Member
    292
    242
    Technology
    Nothing new here. The gas engine is allowed to fire when the car sees fit in the "EV Auto" mode. If you want to keep the engine off, stay in EV mode.
    giora likes this.
  2. fotomoto
    fotomoto Senior Member
    5,632
    3,810
    So. Texas
    Read again.
  3. bisco
    51,843
    ev/ev auto = ev only and ev auto. not a good start to prime life. but there again, something else from toyota said the car goes 25 miles on ev, with the engine running. and danny said no way, ev only. so i'm taking everything with a grain of salt until someone gets there grubby little hands on one.
  4. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    I see no conflict between what Danny (and others) said and the text from o/m quoted here (which I read twice). Only in EV Auto mode the engine may start due to high load requirements. Not in EV mode. Maybe its my English?
    Prashanta likes this.
  5. bisco
    51,843
    you read 'ev/ev auto' to mean 'ev auto' only?
  6. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    This particular condition (in bold) has an asterisk and an explanation at the bottom saying this one refers to EV Auto mode only.
  7. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Correct.
    When power is needed temporarily, for example when the accelerator pedal is depressed firmly or when accelerating suddenly.*
    *: When traveling in the EV auto mode only
    #87 Lee Jay, Oct 25, 2016
  8. Tideland Prius
    16,548
    It's no different from the hybrid parameter descriptions in the Gen 2 and Gen 3 manual.
  9. bisco
    51,843
    i won't repeat myself, since we're running two threads on the same subject.
  10. Trollbait
    12,505
    Yes, I don't think it would be an issue under lighter acceleration, but if dual motors is available in hybrid and EV Auto modes, the system might switch to one motor under heavier acceleration.
  11. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
    As others have said, to start the ICE takes the use of one of the electric motors. So if the two motors are both already at max output to accelerate the car, the car would hesitate and have less power briefly while the ICE was started, wouldn't it. I don't think that would be regarded as a desirable experience for drivers. But I will be interested to find out whether it does this and if so whether drivers to find it ok or not.
    #91 GT4Prius, Oct 26, 2016
  12. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    I agree, and after reading parts of the o/m I tend to believe that the dual motors drive is for EV mode only.
    EV auto may be similar to first gen EV mode. Although MG2 is about 12% less powerful than the PiP one, to maximize efficiency ICE will join well before MG2 reaches its maximum power.
  13. Tideland Prius
    16,548
    Dual motor is not available in HV mode. I asked Kaneko-san directly (Assistant Chief Engineer).
  14. David A. Needleman
    David A. Needleman Junior Member
    San Ramon, CA
    2013 Prius Plug-in
    Just my opinion, but worrying about acceleration times and whatnot in what is designed to be a fuel efficient hybrid vehicle is missing the whole point of owning a plug-in hybrid vehicle - which in my opinion is most importantly to burn less fossil fuel and to emit fewer greenhouse gasses running the vehicle.
    If you want muscle off the line buy a Hellcat, or in the electric vehicle market, a Tesla Model S if you've got 90K+ to spend on a car.
    #94 David A. Needleman, Oct 26, 2016
    ttait and bisco like this.
  15. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    You are taking it a bit to the extreme aren't you?
    Would you accept 18 sec 0-60 with a bit more efficiency?
  16. Lee Jay
    5,850
    4,036
    There's slow-unsafe, and there's not-fast-but-safe.
    Prius is the later. I've driven cars that were slow-unsafe.
  17. bisco
    51,843
    try a 1985 mercedes 300sd, with 65 horses. oh well, with 10 tons of metal around you, i suppose you're fairly safe.
  18. Trollbait
    12,505
    Then there is the sales implications of speed specs. Being the most efficient ICE car most can buy doesn't help much if only a minority are buying it.
  19. El Dobro
    El Dobro A Member
    7,088
    3,270
    Yep, don't see too many commercials where the car is in the slow lane doing 55mph. ;)
  20. bisco
    51,843
    agreed, gen 4 looked pretty nimble in the bank robbery ads, will be interesting to see what they come up with for prime.
