A/C changes from cabin to floor arbitrarily
Discussion in 'Gen 3 Prius Main Forum' started by Phillip Knox, Oct 27, 2016.
  1. Phillip Knox
    Phillip Knox Junior Member
    Oklahoma
    Wife tests me saying the fan is switching from cabin to floor arbitrarily. She'll switch it back, minute later bam! It switches back. What's going on?
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Does she have the hvac system set to auto? If so, auto lets the car decide where to blow the air based on varying criteria. If not set to auto, it'll keep the settings at what she sets them to.
  3. Mendel Leisk
    41,889
    If you set a mode it should stay put. Does she set a mode and then hit Auto? That'll cause such behavior.
  4. bisco
    52,373
    run her in manual, then you get to decide everything.;)
    Raytheeagle likes this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Which part of the equation is being run in manual? If the her is of the feminine gender, getting to decide everything is difficult;).
  6. bisco
    52,373
    yeah, i didn't phrase that too well.:oops:
  7. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    That's ok. The combination still works. Run it in auto and the decision is made for you. Run in manual, you decide what is best. Just like marriage to a certain degree, but without the fear of spending an evening on the couch.
  8. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    And it isn't "arbitrary". It's "pre-programmed". Just not the way she'd like. ;)
  9. StarCaller
    StarCaller Senior Member
    1,279
    730
    Cedar Crest, NM, USA
    this^
    if she changes nething regarding the airflow, the system goes out of auto & stays there //
