Heated LED head lights?
Discussion in 'Prius v Main Forum' started by RB Smith, Oct 28, 2016.
  1. RB Smith
    RB Smith New Member
    Central PA
    2017 Prius v wagon
    Are the headlights on a Prius v Five with the LED lights heated in any way for driving in freezing precip?
  2. Air_Boss
    Air_Boss Senior Member
    4,219
    1,188
    New Yawk
    Not as much as halogens, but if you use a high concentration of the low freeze point washer fluid, the LED headlight washers can assist with deicing.the transparencies.
  3. RB Smith
    RB Smith New Member
    Central PA
    2017 Prius v wagon
    My 2017 doesn't have washers.
  4. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Washers went away in 2014. I think the LEDs will generate enough heat on their own to keep ice off.
    LasVegasaurusRex likes this.
  5. Mendel Leisk
    41,850
    Our 2010 Canadian touring with LED's came with washers (which I've never used, apart from a bit of testing to see if they worked), but yeah, all the 2016/17 Prius hatchback have LED's, but no washers.
  6. RB Smith
    RB Smith New Member
    Central PA
    2017 Prius v wagon
    LED do not make any heat.
  7. bisco
    52,337
    can you add washers?
  8. Mendel Leisk
    41,850
    Maybe they make some heat, just not as much:
    How hot are LED light bulbs? | LIFX
    Have you checked that on yours? I could give it a try too, next time we're driving. I'm disinclined to just turn on the headlights without running the car.
  9. Air_Boss
    4,219
    1,188
    New Yawk
    High power LEDs require fans or external heatsinks. They clearly create heat.
  10. Offline
    Offline Active Member
    646
    240
    Lenexa, Kansas
  11. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    The OEM washers were essentially useless.
  12. Mendel Leisk
    41,850
    I've never had a decent opportunity to try them, we hardly seem to get snow here anymore. My understanding was they were to melt off frozen slush? Considering the aerodynamic shape of the headlights, and that the LED's do heat up some, doubt they were needed in the first place.
  13. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Don't forget in this conversation that the LEDs used to have multiple projectors back in the day when they had washers for them in the bumpers. When they got rid of them was when they switched to a single beam. So with one source of light now, the heat no matter how small it may be is still more than it used to be and enough that the requirement is met that washers are no longer necessary. And not to mention how useless they were anyways, at least IMO. If they were good for anything, it was spraying fluid all over my clean hood/bumper/etc when I didn't want them to.
    Air_Boss and Mendel Leisk like this.
  14. mikefocke
    4,039
    1,834
    Sanford, NC
    Don't EU regulations still require washers? I know Porsche in models just coming out in new bodies still has them.
  15. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I think they do, but I was talking US. If a manufacturer can save some money, they usually but not always, will.
    My 16' XC90 and 17' Q7, both with led headlights, have headlight washers. But they both also have multiple beam low and high beams, not one beam like the mid cycle refresh Prius v.
  16. Offline
    646
    240
    Lenexa, Kansas
    The Hella web page to which I provided a link has the answer: "ECE regulation R48 stipulates the use of a headlight cleaning system for headlights with a light performance of more than 2,000 lumen." The purpose of the requirement is to reduce glare experienced by oncoming drivers. Some car makers put headlight washers on vehicles that have headlights that produce less than 2,000 lumen either as a standard or optional feature.
  17. Bham_prius
    Bham_prius Junior Member
    35
    bellingham
    Wrong
  18. Mendel Leisk
    41,850
    But maybe not enough?
  19. Air_Boss
    4,219
    1,188
    New Yawk
    High power LEDs produce lots of rejected heat, just not in the right places to heat the air within the headlight transparencies.High power LED heatsinks tend to be exposed, outside the transparencies (or behind the lamp mount in an H-series lamp), in free stream air.
  20. Prodigyplace
    12,654
    11,825
    Central Virginia
    That heat & heatsink are in the engine compartment, not outside where the ice & snow are.
