Steel rim hub diameter larger than wheel hub diameter
Discussion in 'Gen 3 Prius Main Forum' started by toyolover, Oct 31, 2016.
  1. toyolover
    toyolover Member
    441
    67
    toronto, canada
    I just purchased a set of used winter tires (same size as the original factory 195/65/15) with steel rims. This morning, I took a closer look at the center hub and notice that the steel rim hub diameter is slightly larger than the wheel hub diameter. The difference is about 1.0-1.5mm (see posted picture). I don't notice any wheel vibrations when driving on highway speed other than higher road noise than the all-season set. The Prius original alloy wheel hub diameter is about 54.2mm while the steel rim is about 56mm. Is this common with after-market steel rims? Do I need a tight fit like the factory original rims?
      File size:
      139.7 KB
  2. StarCaller
    StarCaller Senior Member
    1,277
    729
    Cedar Crest, NM, USA
    Mendel Leisk and toyolover like this.
  3. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    My winter steelies might have a similar problem, but to be honest I've never checked - however, it is most important to use tapered lug-nuts with the steelies (…supplied with the rims I purchased from TireRack), the lug-nuts on the OEM Alloy wheels are flat-faced and have a flat washer and so might not work correctly with the steelies (they'll torque up OK, but will they self centre and remain nice and snug? …now there is the question!) - I would recommend you use the correct lug-nuts and torque them down with your own (calibrated) torque-wrench! - Good luck! - hope this helps - Wil
    toyolover likes this.
  4. BZzap!
    BZzap! Senior Member
    1,607
    878
    ^^^ Agree. If you do install aftermarket wheels you need to use the correct lug nuts that are designed for the wheels. The use of non hubcentric wheels can be dangerous if the wrong lug nuts are used. As stated^^^, the use of adapter rings is the best option.
  5. mrbigh
    3,686
    699
    Long Island, NY
    I had been using the taped lug nuts for the past 10 years for the spare winter tires and I have no complains......
  6. toyolover
    toyolover Member
    441
    67
    toronto, canada
    Thanks so much for all your quick replies. The nuts I am using with the steel rims are not the originals that came with the factory rims. I am using a different set of "ball taper lug nuts" and I will hand-torque them to make sure they are all tight.
  7. toyolover
    toyolover Member
    441
    67
    toronto, canada
    Hi Starcaller,
    Thanks for your detail answer. With regards to the spigot hub ring 56.1 to 54.1, is this the correct size I should be using?
  8. Mendel Leisk
    41,334
    Toyota steel rims (Corolla for example) will be exact fit. But yeah, any aftermarket steel rims have oversized hub openings. They have to, to accommodate a variety of hub sizes. And as @StarCaller says: it'd be best to get adapter rings: ID to match the hub, OD to match the hub opening.
  9. StarCaller
    1,277
    729
    assuming you're 100% sure about the hub diameter of your steel rims, yes/
    the diameter on the car is 54.1mm /
  10. toyolover
    toyolover Member
    441
    67
    toronto, canada
    Spigot does not ship to Canada. I've searched on line but seems like 26.1-24.1 is not a commom size. Also tried a few tire stores but not available. Does any one know of a Canadian vendor? Or may be online vendors that carry this size?
  11. Mendel Leisk
    41,334
    Any tire/wheel retailer will have adapter rings.
  12. StarCaller
    1,277
    729
  13. toyolover
    toyolover Member
    441
    67
    toronto, canada
