I'm an idiot in need of help
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by photobrad, Nov 1, 2016.
  1. photobrad
    photobrad Junior Member
    US
    Trying to jump another car off of the engine compartment terminal on my 2005 Prius, and got the cables crossed. As the title states, I'm an idiot. Not surprisingly, this killed the car.
    I've replace the 120a fuse that is on the battery in the back. Now, when I put my foot on the brake and hit the POWeR button, all that happens is the light on the POWER button blinks.
    Any ideas what I should do next?
    Any and all help is greatly appreciated, thanks in advance.
  2. fuzzy1
    10,564
    Can you go into Accessory mode (hit the Power mode without foot on brake) and get the various 12V systems to boot up? Dashboard, audio, NAV, lights, ventilation, etc.? If the fusible link is properly replaced, all or most of these should still work.
  3. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Fuzzy mentioned the fusible link and i would start there. You replaced the fuse at the battery (was it blown?) but the fusible link is under the hood by the jump points. That strange piece of stamped copper. Measure the resistance between the ends and see what's up.
    The car generally tries to protect itself so hopefully that is all it is. But there have been cases where the link doesn't blow fast enough and thats multi-thousand dollar damage to lots of systems.
    I would strongly suggest investing in "smart" jumper cables. I am a strong advocate for them. This is the model I have from 6+ years ago, they may not make them anymore, I don't know:
    They connect dead, and after everything is connected then they test polarity and connect automatically. No sparking, no way to reverse the leads, and if something terrible happens and things short, the "smarts" fry first not the car. Worth every penny and the LEDs are super nice.
    Merkey and wjtracy like this.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    The 12 may be dead or the fuse replacement not done well.
    Easy way to check is with voltmeter across underhood jump points.
    If good there check in that fusebox the jumpoints are in
    Usually try big one under the clear plastic opens up.
    If 12 good there and no fuses blown usually the Inverter is blown and
    Has to be replaced,
    Seen that many many times here over 10 years.
  5. photobrad
    US
    Nope!
  6. photobrad
    US
    12v is newer and fully charged (checked it with voltmeter)
    Good continuity across the 120a fuse I installed over the battery
    Good continuity across the big fusebox.
    How bad is installing a new inverter on that car?
  7. fuzzy1
    10,564
    Then I very strongly suspect something is still not fixed in the 12V system. Don't think about a new inverter yet, get all the 12V stuff working first.
    Do you have 12V at under-hood jump points? At the many fuses in the fusebox?
  8. photobrad
    US
    Yes, I have 12v at the under hood jump points. Apologies, I'm not sure how to test the "many fuses in the fusebox"... would that be removing fuses and sticking the probe in its place? Thanks for your time.
  9. Patrick Wong
    18,210
    6,511
    Look at the fusible link assembly located within the large relay/fuse box next to the inverter. The fusible link is housed in a 5" long plastic box with a clear cover and whitish sides. Use a flashlight to inspect the DC/DC fusible link. If it is blown you need to replace the entire 5" box - which is not particularly easy to achieve as the large relay/fuse box has to be unbolted to gain access to the underside.
    If that link is OK, check the DOME fuse.
    If that fuse is OK and you still have a problem, remove each fuse, one at a time, and measure continuity across the fuse, using an ohmmeter. Do not rely upon visual inspection.
    If the fuses are OK (check the fuses in the fuse box under the driver's side instrument panel as well) then you probably have to replace the inverter.
  10. photobrad
    US
    Fusible link is fine, did visual and continuity test with voltmeter. I'll try the other things. Thanks.
    SM-G935V ?
  11. photobrad
    US
    I looked at the fusible link one more time, and I didn't see where it is indeed broken. Going to replace that if I can find one today. Thanks again.
    fuzzy1 likes this.
