Ok Now Would you Buy a Prime? (POLL)
Discussion in 'Prime Main Forum (2017-2022)' started by inferno, Oct 26, 2016.
  1. No ... need 5 seats.
    14 vote(s)
    15.7%
  2. I'll wait until the Solar Option comes out.
    8 vote(s)
    9.0%
  3. Need a spare tire.
    9 vote(s)
    10.1%
  4. The trunk space is too little (cargo space decreased by 2")
    11 vote(s)
    12.4%
  5. I wouldn't buy anyway.
    3 vote(s)
    3.4%
  6. Heck yeah, I would buy!
    48 vote(s)
    53.9%
  7. Not enough EV range still...
    17 vote(s)
    19.1%
  8. Don't care
    1 vote(s)
    1.1%
Multiple votes are allowed.
  1. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    Yes, I know, however I like them.
  2. Tideland Prius
    16,615
    Me too. That is cutting edge technology that the Prius is known for.
  3. Trollbait
    12,676
    Because those fog lights aren't really fog lights, and only help without fog.
  4. KrPtNk
    KrPtNk Active Member
    323
    283
    Pacific Northwest
    How do you know this?
  5. Trollbait
    12,676
    Cars in the US haven't had real fog lights for quite some time. Some are actually honest and call them driving lights.
    Evidence for this is the fact that they can't turned on without the headlights. In real heavy fog, the headlights reflect back to the driver and obscure vision worse than the fog alone. Then US spec cars don't have rear fog lights to be better seen by approaching cars.
    Further evidence for or against them being fog lights can be found in what spectrum they produce. Fog lights used to be yellow because yellow wavelengths didn't scatter, and reflect back, in fog as badly as blue ones. It is possible to make a fog light that appears white to human eyes, but still have better penetration in fog than a regular white bulb though.
    Felt, Prius Maximus and KrPtNk like this.
  6. KrPtNk
    323
    283
    Pacific Northwest
    You are probably right, but this is a new model of car and there is a chance that the fog lights might be improved. I want to keep hope alive.
  7. Prius Maximus
    956
    811
    Northeastern IL
    Truth, but they don't work as driving lights either. All fog lights do these days is light up the ground right in front of the vehicle, giving a false sense that there is more usable light. The only benefit is at dawn or dusk when it's raining or just wet, the fog lights reflect back off the wet road helping you see the lane markers more than the headlights which tend to reflect up and away from you. The fog/driving lights do not shine down the road far enough for use as driving lights. Try tin foil on the headlights and see the pattern.
    A true fog light is low to the ground, theoretically to get beneath the fog layer, and shine the light under the fog and down the road. Backscatter results when the fog light is within the fog layer, but having it low helps because the reflected light is also lower. It's true that yellow light is reflected less, but all colors scatter and reflect, just not as much as blue. Look at a rainbow, remember Roy G. Biv?
    The fog lights in my pickup turn on separately from the headlights. They are mounted low, but it's a 4WD, so they are not low enough. But the vertical distance from my eyes to the fog lights helps, even though the lights aren't beneath the fog.
    The way fog lights are implemented in the US today, they are useless.
  8. axle2152
    axle2152 Active Member
    266
    210
    Atlanta, GA
    2018 Prius Prime
    I don't know about you but the LED headlights seem to be plenty bright and I've noticed that in the fog I don't get quick as much reflection with the LED, not sure if that is due to the spectrum of the LED over halogen, it being a projection lens or what but seems to work well enough without fog lights...
  9. Prius Cop
    Prius Cop Junior Member
    48
    17
    Alabama
    I would buy a Chevy Volt before I would buy a Prime.
    mmmodem likes this.
  10. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    I'd take my bicycle over any GM product.
    GT4Prius, Prius Maximus and avid like this.
  11. Archimedes
    Archimedes Junior Member
    70
    45
    Because of the line electric mileage?
  12. Prius Cop
    48
    17
    Alabama
    Yes, the Volt has much better range.
  13. Lee Jay
    5,850
    4,036
    Much less total range, much poorer mileage on both gas and electricity, and much less back seat room, all for an extra $6,000 or so.
    inferno and Prius Maximus like this.
  14. ETC(SS)
    7,348
    So far.....all, things being equal?
    +1
    Besides.....the Prime appears to be a compliance vehicle.
    I don't think it's 50-state available (yet?)
    I'm waiting for some real world data on range/MPG for both vehicles.
    Hypercommutters in SoCal might be better off with the Prime if the MSRP is as advertised, and they don't "Leaf" the real electric range.
  15. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    Zero-state available currently. Should be 50 state available by February.
  16. Prius Cop
    48
    17
    Alabama
    It shows you haven't done your research.
  17. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Can you be more specific on the research?
    Your profile shows you have already a BEV. Is the Volt intended to replace it?
  18. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    Just started smelling like a rat in here.
  19. Prius Cop
    48
    17
    Alabama
    I don't own either yet, but have researched both. There are many Volt owners that go MONTHS without using any fuel. So your mpg quote is wrong. Only when using gas will your statement hold up. Styling is much better in the Volt also. I thought the Prime was only 25 mpg. Volt more than doubles that.
  20. silverone
    silverone Member
    84
    34
    Ohio
    2014 Chevy Volt
    You'd be surprised how little range matters when EV mileage is adequate for your commute. I've gone from between 8,000 to 25,000 miles between gas fillups in a Gen 1 Volt and would do much better with a Gen 2 or BMW i3. I filled my Gen 2 Prius every 5 days..
    Gas mileage and EV efficiency are not as important in this circumstance either. I've averaged burning one gallon of gas per 1,000 miles or so, even at low MPG I'm okay with it. In my area, electricity is approximately 1/2 the cost of gas and I get free charging for two-thirds of my commute.
    Won't argue space at all, but few GM products sell at MSRP very long. Volts are going for many thousand under MSRP with a bigger EV tax credit, so I doubt transaction prices will be $6,000 different.
    Trollbait likes this.
