Replace turn signal/DRL unit?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Raven65, Feb 4, 2016.
  1. Raven65
    Raven65 Junior Member
    SC
    Hi all,
    Caught a rock in the left turn signal/DRL unit of my 2012. I've already bought a replacement (roughly $100 for an aftermarket TYC from Amazon), but I'm not sure how difficult it is to swap it out. Has anyone done it? Any tips?
    XT1060 ?
  2. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    It's easy, you can access the housing from below. Remove a few fasteners from the triangular cover under that corner and reach up.
    Or, if you really want to see what's going on behind the bumper cover, remove it for even more room to work with. This is for a 2010, but things shouldn't be too different:
    DIY: How to black-out the headlights on a 2010+ Prius | Balancing Act
  3. kenp11
    kenp11 Junior Member
    74
    Orange
    2014 Prius Plug-in
    Did you get the black clips that hold the assembly to the bumper with the light? They are on the top & bottom of the light
