Service repair manual for 2016 Prius
Discussion in 'Gen 4 Prius Technical Discussion' started by jadziasman, Oct 29, 2016.
  1. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    Has anyone bought a TIS subscription specifically to access the Gen 4 service repair manual?
    It just occurred to me this morning that the answer I'm seeking regarding the way the modules are connected to each other (welded or fastened) on the NiMH HV battery should be in the manual.
    However, I'm not willing to pay $15 to see if the information is available since I don't own a Gen 4 and won't be buying one in the foreseeable future.
  2. JDenyer232
    JDenyer232 Member
    44
    48
    Maine
    Yes I have gone through the service manuals as well as the new car feature sections. There is no mention of how the bus bars are fastened. Hope this helps.
  3. kowee
    kowee Junior Member
    Hungary
    I downloaded already. Took 16 hurs to download everything in html, now I'm combining into one pdf :)
    About 2000 chapters. :)
    Jburner, bisco, Elt31987 and 4 others like this.
  4. hassan310
    hassan310 Junior Member
    29
    PK
    Would you mind sharing it?
    SFO likes this.
  5. Zardoz
    Zardoz Member
    86
    52
    Show Low, AZ
    I have a 2017 Prius Two. I am looking for the TIS service manuals. In particular I need troubleshooting flowcharts for the AC / Heat automatic control system. My car seems possessed and Toyota cannot find anything.
    Recommendations?
    Thanks!
  6. Fester
    Fester Active Member
    201
    198
    Ohio
    Although I've never had any significant issues with my 2017 Prius 2, my former 2008 Gen 2 would sometimes act a bit odd, and I found that disconnecting the 12v aux. battery, waiting a few minutes then reconnecting would force a "cold reboot" of the various system computers and except for needing to reset the clock, and losing "tripmeters" to zero (main odometer not affected), it usually fixed the mysterious problem. Certainly wouldn't hurt to try.
    knockknock_2 likes this.
  7. Elektroingenieur
    2,515
    3,287
    Three Touring
    Your local public library offers access at no charge to the Chilton Library service, which includes the text and illustrations from Toyota’s Repair Manual for the 2016 Prius, which also covers your car. Look under 2016 Toyota Prius > Repair > Heating, Ventilation, & Air Conditioning > Heating & Air Conditioning > Air Conditioning System.
    SFO, BlinkerFluid and knockknock_2 like this.
  8. Mandrade007
    Mandrade007 Junior Member
    Mexico
    Two Eco
    Are you gonna Share it?
    Elt31987 and kenoarto like this.
  9. Sadripper
    Sadripper Junior Member
    Poland
    Three Touring
    I would be very grateful if you do...
    Elt31987, Mandrade007 and kenoarto like this.
  10. doctorman
    doctorman Member
    210
    36
    NY 11020
    anyone got the service manual at the end?
  11. Houssam Moustafa
    Houssam Moustafa Junior Member
    New Jersey
    Two Eco
    I tried to get a 2-day subscription to test it out. They withdrew the money, but I can't login. Then reading through the FAQ, I found out that TIS does not work on MACs; just Windows. Has anyone gotten TIS to work on a MAC?
  12. bisco
    52,375
    idk anything about computers, but isn't there a windows program that runs on mac?
  13. Mendel Leisk
    41,889
    Here's a pdf. Not the best, the bookmark menu gets a little weird if you go down more than one layer, and it's all just sorted alphebetically (install proceeds removal, for example). And of course the blue-box links are broken.
