What is the name of the light above day time running light?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by nicolas_xu, Nov 7, 2016.
Tags:
  1. nicolas_xu
    nicolas_xu Junior Member
    31
    I'd like to know the
    1) name
    2) spec
    of the light that is in the front of the car, above the day time running light, at the same section of day time running light.
    I know it is not fog light, because my Prius doesn't have fog light. It is been puzzled me for a long time. Thank you!!
    - Nick
    I found the following lights on Amazon:
    (Copy and search on amazon)
    JDM ASTAR G1 8000 Lumens Extremely Bright H11 H8 COB LED Headlights, Xenon White
    Do you think it is worth buying? Why? Thank you!
  2. Tideland Prius
    16,566
    Indicators/turn signal
    WY21W (21W) wedge-based bulb.
    Hopefully someone here with experience with replacing the headlights with LEDs can chime in. Most of us still stick with HID as a replacement or retrofit. These LEDs use about the same amount of power as HID (Amazon says 36W per bulb. HIDs are 35W per capsule).
  3. nicolas_xu
    31
    The light is white color, not orange. So it is not turn signal. What name can it be?
  4. Tideland Prius
    16,566
    Well based on your description, that's the best I can do.
    The LED DRL and the turn signals are in the same housing like you described. You have a 2014 Prius so that's where the DRLs are. The only other lights are your low beam, high beam, forward-facing parking light and side-facing parking light.
