transmission oil/gear oil change
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Omair Majeed, Nov 9, 2016.
  1. Omair Majeed
    Omair Majeed New Member
    Pakistan
    2012 Aqua
    hi I own a 2012 model toyota aqua (prius c Japanese spec) I imported it and it had done 30000 km....its mileage now is 60000km....should I now change transmission oil...keeping in view that temp in my city goes as high as 49 C in summers .....plus when should the engine plugs be changed
  2. b100
    b100 Member
    145
    75
    Netherlands
    I recommend to change the transoil at 100.000km and the spartplugs can go at least 150.000 to 200.000km
    But you can find these things in other topics on the forum.
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  4. Omair Majeed
    Pakistan
    2012 Aqua
    thanks guys but can u just give an input....does environmental factors like temperature ....dust level can have an impact on change interval for transmission oil
  5. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    It certainly may. Toyota did not specify an interval, so we are all just making up our own.
  6. Mendel Leisk
    41,814
    An early transaxle fluid change is what I'd recommend, even at 10,000 mile or 12 months it'll come out suprisingly dark. Then you can stretch it. The second change will likely be a lot cleaner.
