Tire Pressure on Fuel Economy
Discussion in 'Gen 2 Prius Fuel Economy' started by perry470, Nov 9, 2016.
  1. perry470
    perry470 Junior Member
    San Francisco
    I've been driving my '08 Prius for five weeks (~1,800 miles) and the tire pressure was 34/34 when I bought it from the previous owner. I was getting 55~57 MPG. After the last fuel-up, I decided to increase the tire pressure to 40/39. And today at the fuel-up, I found that my last tank did 61.5 MPG! (My first 60+ MPG tank, woo!)
    So a 15% increase in pressure tire results in a 10% increase in fuel efficiency? That seems a little too good to be true. I was expecting something like a 5% increase. But 10%? I attribute this largely to the fact that I knew increasing tire pressure will result in better fuel economy. Confirmation bias was at play here. I may unconsciously drove with a more aggressive hypermiling style. If I want to be scientific about this, I would have to let someone else change the tire pressure for me without telling me.
    Putting that aside, what's your experience on increasing tire pressure for fuel efficiency? Is it better? How much better? Share your results!
  2. Mendel Leisk
    38,726
    Yeah likely is, and I'd agree with your reasons. Obviously there could be a slight increase, but luck, driving conditions, ambient temps, and your driving style all play a factor.
    I went the other way: when we first had our Prius (with 215/45R17) I raised pressures to over 40 psi, like I typically did with our previous car, which had 195/65R15 size. Someone here mentioned keeping the 17" pressures around 34~36 psi, more comfortable, little or no drop in mpg. That was my experience. The 17" spec'd pressure is lower, 33/32 f/r, I go with 34 all around.
    BassCadet likes this.
  3. dolj
    dolj Senior Member
    7,655
    3,867
    Wellington, New Zealand
    What you have observed is the benefit of correctly inflated tires. Without a doubt, 34F/34R PSI is under inflated.
    From observation of tire wear, it indicates the placarded pressures of 35F/33R PSI leaves the tires under inflated. The sweet spot where you get maximum improvement is around 39F/37R PSI; after that the benefit and safety decreases. (Just in case you were thinking 15% increase - good, therefore 30% increase - better; it won't. It does not extrapolate in a linear fashion.)
    I run my tires at 39F/37R and as the tyre wear indicates this the correct inflation pressure, for the tyres on my car, it also gives much better FE (fuel economy).
    I can't say exactly as tire pressure is only one of a few variables that can affect FE. But just changing tire pressure (up to the correct pressure) makes an improvement in FE. This makes sense as under inflated tires makes for higher rolling resistance. This is true across all tires, not just those marked LRR (low rolling resistance).
    I would never advocate running on over inflated tires. You will wear out the tires faster and it is not safe. Always try to keep the tires inflated at the correct pressure.
    With all due respect Mendel, comparing 17" wheels with LP tires and 15" wheels with SP tires is like comparing apples and oranges.
    #3 dolj, Nov 9, 2016
  4. bisco
    49,489
    i run 40/38, but the mpg increase is not measurable by eyeball. perhaps lab testing would offer better insight. you can always try nitrogen...
    Azam likes this.
  5. CooCooCaChoo
    CooCooCaChoo Senior Member
    901
    504
    Cow-lee-fornia
    2023 Prius
    Don't get too excited, you live in San Francisco. Going down the hills really helps boost your MPGs. Get out of the hills and onto flat roadways elsewhere in California and you'll notice a decrease in economy.
  6. Mendel Leisk
    38,726
    I tend to do better on flat. Trouble with hills: they go down and up.
    Data Daedalus, Danielsan and bisco like this.
  7. dolj
    dolj Senior Member
    7,655
    3,867
    How do you go down a hill without first going up? There is always a net loss (up a hill then down the hill), so your statement makes no sense.
    Data Daedalus likes this.
  8. Mendel Leisk
    38,726
    Plenty of examples. Here, you can constantly go downhill or uphill:
    douglasjre and priusmagic like this.
  9. RootBreaker
    RootBreaker Member
    98
    52
    Williamstown, NJ
    well I have a 2014 with 68k miles now. I am up for tires...
    When I take my car in to the dealership for an oil change they let all my air out. I then get 53mpg... and i go... CRAP I FORGOT... over to Wawa for air and Viola... back to 63-70mpg.....
    I run 43/43 (f/r)
    I am going with a totally different tire so hopefully I dont take a mileage hit... Hankook Optimo H727
  10. RootBreaker
    RootBreaker Member
    98
    52
    Williamstown, NJ
    fyi I just see my fuelly now.. LOL.... ummm that was at 34/34 air... then I saw the light.. and i dont have time to track all my fillups...
  11. Kevin_Denver
    Kevin_Denver Active Member
    581
    422
    Denver, CO
    There are a lot of factors at play. If you drive a lot of roads at lower speeds (e.g. 25-55mph) without much braking, then the rolling resistance of the tires will be a large portion of the energy use of the car. However if your drive involves lots of braking or high speeds that incur lots of air resistance, rolling resistance will play a smaller function.
    There's a good chart on this page that I feel is pretty accurate: Tire pressure for 2014 Prius | PriusChat
    You can see that that increases from 35 to 50 are fairly marginal, going from 48 to 49.5mpg. I agree that the increase in fuel economy you're seeing likely has more to do with a change in driving style instead of increased tire pressures. However the tires pressures didn't hurt ;)
  12. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    The great "PSI experiment" is over, for me. I'm back down to factory specs. And I haven't noticed any decrease in mpg.
    This is my first Prius, so I don't know if the Gen4 suspension is more sensitive to changes in PSI... or if it's just my Toyo tires. But I got tired of the stiff and harsh feel every time I went over even a small bump or imperfection in the road. I was only 5 PSI over specs, but the ride quality was more degraded than I was comfortable with. And I also noticed occasional rattles in the dashboard.
    Now that I'm back down to down to 36, everything is smooth and comfortable again.
  13. Bluegrassman
    Bluegrassman Active Member
    229
    185
    US
    Our '09 seems to demonstrate a much harsher ride at increased tire psi than our '12 does
    douglasjre likes this.
  14. Mendel Leisk
    38,726
    Higher pressures have got to have some impact on shocks, suspension and wheel bearing longevity. I push pressures up but only slightly.
  15. Coast Cruiser
    2,267
    2,571
    Where is ETP hiding???
    "42 PSI is the answer to all things in the Universe."
    Yeah, it's good, right up to the point where your teeth rattle out of your head! :eek:
  16. Mendel Leisk
    38,726
    With 15" tires 42 psi feels not bad, but with low profile 17" harsh ride.
  17. RootBreaker
    RootBreaker Member
    98
    52
    Williamstown, NJ
    I will let you know next week! as I will be getting my new tires tomorrow. Stretched 68k out of the factory 195's and just dont feel comfortable completing my 65 mile commute (1 way) in them...
    well I guess I dont mind the stiffer ride as my 1978 chevy 1 ton rolling on 40" bias ply hawgs will shake the snot out of ya....
    Coast Cruiser likes this.
  18. bisco
    49,489
    my new michelins came back at 36 all around. very smooth and comfortable. i'll pump them to 40f/38r like i had the oem's, to see if there's much difference in ride quality.
  19. Mendel Leisk
    38,726
    Or..., leave 'em where they are, try a tank, see if there's any drop? Or an uptick due to having the LRR champions. :)
    What were the old ones?
  20. bisco
    49,489
    forgotten already. goodyear assurance i think. the trouble with trying a tank, is that i have nothing to compare it to, unless there's a major change. a few mpg either way can have a lot of different causes. just going by my local ev miles, they are similar, even at the lower psi.
