Prius Two Eco with Heat-Insulating Windshield - Confirmed
Discussion in 'Gen 4 Prius Main Forum' started by Tideland Prius, Nov 14, 2016.
  1. Tideland Prius
    16,548
    Well after a year of guessing whether the Two Eco has a special windshield, it's finally explicitly mentioned in the press release for 2017.
    Here's the rest of the press release
    Here's the link, which I presume has a time limit and may be broken in a few years
    2017 Toyota Prius Liftback Shatters Even the Loftiest of Expectations -- Again | Toyota
  2. hyhi
    hyhi Member
    163
    48
    fl
    So the 2016 two eco had it as well?
  3. Tideland Prius
    16,548
  4. bisco
    51,843
    do all the gen 4 get the ceramic heater?
    Coast Cruiser likes this.
  5. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    Hopefully, the Thermo-Tec Lime Green paint isn't too far behind.
  6. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Yes, I'm 99% sure it's part of the heater core assembly, which is part number 87107-47080 for all of them.
    And, in fact, every Prius has had it. Even NHW10 and NHW11 have a "quick heater" assembly, which is PTC ceramic heaters.
    roadwarrior28, RCO and Coast Cruiser like this.
  7. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Did anyone else notice this?
    ***Automatic headlamp leveling keeps the beams focused on the road and helps prevent blinding drivers in oncoming vehicles.
    Is that "automatic leveling" omething new for all models in 2017? Toyota must have listened to the complaints.
    ***Toyota, though, went above and beyond to make the current Prius exceptionally quiet on the road. A sound-insulating laminated windshield and numerous sound absorbers in the dash structure reduce noise intrusion. Higher-grade models feature sound-insulating laminated front door glass, as well. The carpeting is backed by a thick silencer pad, and a urethane-based headliner, along with the ribbed structure of the front pillar trim, helps absorb sound.
    This part: "higher-grade models get sound-insulating laminated front door glass, as well." I believe that feature should be on all Prius models. I get a significant amount of noise through my door glass. And I think the "numerous sound absorbers in the dash structure" are missing in my Three model. Excessive cabin noise, has been my number one complaint since day one.
  8. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    Here's the line from the 2016 press release:
    Return of the Disrupter: All-New 2016 Toyota Prius Rewrites the Hybrid Rule Book It Created | Toyota
    So, there'll be a baseline adjustment, and then the leveling will be to adapt to suspension loading differences.
    Coast Cruiser and RCO like this.
  9. Coast Cruiser
    2,267
    2,571
  10. Coast Cruiser
    2,267
    2,571
    "labyrinth-style clips in the door drain holes prevent sound from intruding yet still facilitate drainage."
    That's very interesting. So now we know what those clips are for on the bottom of the doors. (The clips that fall off... but we won't mention that. :D)
    RCO likes this.
  11. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    Baseline adjustment is probably wrong.
  12. Coast Cruiser
    2,267
    2,571
    And why does only the ECO model get the heat-insulating windshield glass.
    Don't the rest of us get hot, too? :LOL:
    Dragon Rider and RCO like this.
  13. raspy
    raspy Senior Member
    438
    699
    London, UK
    Dragon Rider and Coast Cruiser like this.
  14. bisco
    51,843
    too bad, i was hoping it was improved. i've never felt any warmth without the ice running.
  15. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
    UK models didn't have any quick heater assembly AFAIK. Wonder whether UK Gen4s have this.
    RCO likes this.
  16. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    We have a "Fast" setting on the heater so I'd guess we do have it.
    RCO likes this.
  17. Dragon Rider
    Dragon Rider Active Member
    344
    212
    Miami
    I think they all have it . Except the 2 trim .
    To ease the load on the climate control system, the 2016 Prius comes with a heat-insulating windshield in the Eco trim to ensure that infrared ray transmission is reduced and the cabin is comfortable in hot weather. A positive temperature coefficient ceramic heater warms the cabin quickly without relying on the engine coolant to get up to temperature.
    #17 Dragon Rider, Nov 16, 2016
  18. Coast Cruiser
    2,267
    2,571
    I just turn up the temperature switch... is that the "heater?"
    kithmo likes this.
  19. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Put another log on the burner CC :)
    bisco, RCO and Coast Cruiser like this.
  20. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    It is hard to notice the PTC heater. It's pretty low power. Falls flat on its face here in Edmonton when it's -20C. ;)
    I did notice it one day when it was +10C.
