Scheduled Maintenance
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AmericanIdiot, Nov 17, 2016.
  1. AmericanIdiot
    AmericanIdiot Junior Member
    46
    This is from the 2007 Toyota Prius Scheduled Maintenance Guide
    5k / 6months
    1. Replace engine oil and oil filter
    2. Rotate tires
    3. Visually inspect brake linings/drums and brake pads/discs
    10k / 12months
    2. Rotate tires
    15k / 18months
    2. Rotate tires
    4. Inspect
      1. Ball joints and dust covers
      2. Brake lines and hoses
      3. Drive shaft boots
      4. Engine coolant
      5. Exhaust pipes and mountings
      6. Radiator, condenser and intercooler
      7. Steering gear box
      8. Steering linkage and boots
    20k / 24months
    2. Rotate tires
    25k / 30months
    2. Rotate tires
    30k / 36months
    2. Rotate tires
    3. Replace engine air filter
    4. Inspect
      3. Brake linings/drums and brake pads/discs
      4. Differential oil
      5. Drive shaft boots
      6. Engine coolant
      7. Exhaust pipes and mountings
      8. Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses
      9. Fuel tank cap gasket
      10. Radiator, condenser and intercooler
      11. Steering gear box
      12. Steering linkage and boots
      13. Transmission fluid or oil
    5. clean/adjust rear brakes (according to https://priuschat.com/threads/what-services-you-need-and-what-you-dont.28970/)
    35k / 42months
    2. Rotate tires
    40k / 48months
    2. Rotate tires
    45k / 54months
    2. Rotate tires
    4. Inspect the following:
      4. Engine coolant
      6. Steering gear box
      7. Steering linkage and boots
    50k / 60months
    2. Rotate tires
    55k / 66months
    2. Rotate tires
    60k / 72months
    2. Rotate tires
    3. Replace cabin air filter
    4. Replace engine air filter
    5. Inspect the following
      4. Differential oil
      5. Drive belts
      6. Drive shaft boots
      7. Engine coolant
      8. Engine valve clearance
      9. Exhaust pipes and mountings
      10. Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses
      11. Fuel tank cap gasket
      12. Radiator, condenser and intercooler
      13. Steering gear box
      14. Steering linkage and boots
      15. Transmission fluid or oil
    6. clean/adjust rear brakes (according to https://priuschat.com/threads/what-services-you-need-and-what-you-dont.28970/)
    65k / 78months
    2. Rotate tires
    70k / 84months
    2. Rotate tires
    75k / 90months
    2. Rotate tires
      3. Drive belts
      4. Drive shaft boots
      5. Engine coolant
      6. Exhaust pipes and mountings
    80k / 96months
    2. Rotate tires
    85k / 102months
    2. Rotate tires
    90k / 108months
    2. Rotate tires
      4. Differential oil
      5. Drive belts
      7. Engine coolant
      8. Exhaust pipes and mountings
      9. Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses
      10. Fuel tank cap gasket
      11. Radiator, condenser and intercooler
      12. Steering gear box
      13. Steering linkage and boots
      14. Transmission fluid or oil
    95k / 114months
    2. Rotate tires
    100k / 120months
    2. Rotate tires
    3. Replace engine coolant
    4. Visually inspect brake linings/drums and brake pads/discs
    5. Replace transaxle / inverter coolant (according to Bentley's Toyota Prius Repair and Maintenance)
    6. Brake flush (according to https://priuschat.com/threads/what-services-you-need-and-what-you-dont.28970/)
    105k / 126months
    2. Rotate tires
      3. Drive belts
      5. Engine coolant
    120k / 132months
    2. Rotate tires
    4. clean/adjust rear brakes (according to https://priuschat.com/threads/what-services-you-need-and-what-you-dont.28970/)
    125k / 138months
    2. Rotate tires
    130k / 144months
    2. Rotate tires
    5. Replace spark plugs
    6. Inspect the following
      4. Differential oil
      5. Drive belts
      7. Engine coolant
    #1 AmericanIdiot, Nov 17, 2016
  2. AmericanIdiot
    46
    Here's the summary version:
    Every 5k / 6months:
    2. Rotate tires
    Every 15k / 18months (in addition to above):
    1. Inspect
      3. Drive belts (>= 60k / 72months)
      5. Engine coolant
      7. Radiator, condenser and intercooler
      8. Steering gear box
      9. Steering linkage and boots
    Every 30k / 36 months (in addition to above):
    1. Replace engine air filter (>= 60k / 72 months)
    2. Inspect
      1. Differential oil
      2. Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses
      3. Fuel tank cap gasket
    3. clean/adjust rear brakes (according to https://priuschat.com/threads/what-services-you-need-and-what-you-dont.28970/)
    Every 60k / 72months (in addition to above):
    1. Replace cabin air filter
    2. Inspect
      1. Engine valve clearance
    Every 100k / 120months (in addition to every 5k / 6month):
    1. Replace engine coolant
    2. Replace transaxle / inverter coolant (according to Bentley's Toyota Prius Repair and Maintenance)
    Every 120k / 144months (in addition to above):
    1. Replace spark plugs
    #2 AmericanIdiot, Nov 17, 2016
  3. AmericanIdiot
    46
    The Canada Prius Scheduled maintenance deviates from the above (and seems much more aggressive about fluids):
    Every 10k:
    1. Replace Cabin Air Filter
    Every 60k:
    1. Replace Hybrid Transaxle Fluid
    At 80k and every 40k following:
    1. Replace Inverter Coolant
    2. Replace Super Long Life Coolant
    Every 120k:
    1. Replace Iridium Spark Plugs
  4. bisco
    52,277
    thanks!(n)
  5. AmericanIdiot
    46
    Is there anything I'm missing or needs to be done for high-mileage Gen2s?
  6. Mendel Leisk
    41,822
    Couple of thoughts:
    1. Where you say "replace" engine or cabin filter, is that how it's worded in the documents, or is it more along the lines of "inspect, clean and/or replace"? With the cabin air filter in particular I'm inclined to just clean (brush, tap, and blow air through in reverse direction) and reinstall, until it's gasping to be replaced. With the engine air filter, I wouldn't attempt to clean any more than a bit of tapping, but still would not knee-jerk replace at the service interval, especially if it's barely dusty.
    2. Where you say "visually inspect brake...", are you sure there's not a difference on some of those, periodical another expression is used, meaning a more in-depth brake inspection? In other words, some brake inspections are a cursory visual inspection, but once in a while a thorough inspection is specified, involving some disassembly, measurement, clean and lube. Check the wording.
    Having done the legwork, maybe you should make a table format schedule for US second generation, I did something like that for third gen. The interval-by-interval format of the US schedule has it's pros-and-cons. The main downside I think, comparing to table format: it's hard as heck to see the patterns, kind of irritating. I found too when I made a table format conversion of 3rd gen: there were a few anomalies, ie: they missed a few services, for no good reason, likely just oversight.
  7. AmericanIdiot
    46
    That's how it's worded in the documents. I feel like the filters are pretty cheap so I just replace them on schedule.
    Again, it's straight from the SMG. I'm at 135k miles and haven't had to change my brakes although I'm thinking it'll be soon.
    I'll look into it. The main thing I was worried about is for stuff that's not in the SMG. Some of the "lifetime" things aren't covered (transaxle fluid, etc) and I had to find them in other sources (Bentleys, Toyota Canada). I'm hoping the collective knowledge will fill in any gaps.
  8. Mendel Leisk
    41,822
    (above is a snapshot, response by @AmericanIdiot)
    An in-depth brake inspection is spec'd every 30,000 miles or 3 years (whichever comes first). This is (obviously) the 04 schedule, closest pdf I had, but I think if you check your booklet you'll see similar.
    Really: if you've gone 135,000 miles, had the car since new, you're way overdue.
  9. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    Have you read the "sticky" thread above about what services you need and what you don't? There's some good history and advice there.
    Probably one of the best things one can do for an aging Prius is get in the habit of checking the engine oil level every couple of fill-ups. Most owners don't have to do a thing for the first 120 or 150K miles, and get complacent about some of the basics.
    I think my schedule mentions a brake fluid change at 60 or 100K. That may be important for the health of the expensive accumulator on these cars.
    I think it mentions the PCV valve when spark plugs are done at 120K miles.
    Commonly heard on this site, and I've seen it documented elsewhere, is to change coolant in both systems every 50K miles after the first 100K mile change. That's less aggressive than the Canadian schedule but it's the same idea.
  10. Mendel Leisk
    41,822
    Canadian Prius maintenance schedule, from 2014 onward, says 48,000 km's (30,000 miles) or 3 years (whichever comes first), for brake fluid change.
