Is there a control to trigger the auto headlights earlier?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Jim in NC, Nov 18, 2016.
  1. Jim in NC
    Jim in NC Active Member
    217
    266
    28
    Myrtle Beach, SC
    I normally keep my AUTO headlights setting on, but under certain conditions it seems they don't come on when I'd like:
    • If it is darker because it's begun raining
    • At dusk when I'm heading into the sun
    If anyone knows how to adjust this, please let me know...
    alanclarkeau likes this.
  2. booke02
    booke02 Active Member
    391
    415
    Israel
    It is one of those settings that are set via the OBD2 connector. You dealer can do it, but, unless they are really nice, they will probably want to charge you for the service. If you have a OBD2 adapter, you can use something like Carista and modify it yourself.
    kithmo likes this.
  3. Jim in NC
    217
    266
    28
    Myrtle Beach, SC
    Thanks! I have a Carista so I will do some investigating this weekend and see if I can adjust it.
  4. first_superior_prius
    76
    115
    Michigan
    There's an easy solution... just turn your headlights to "on" when you get in the car
    it's what we've done for the better part of a century and it's worked out just fine so far
    Mendel Leisk and RCO like this.
  5. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Stick a piece of paper over the sensor. That's how I did it in my Corolla on cloudy or rainy days. It was annoying having the lights cycle on and off constantly.
  6. wrprice
    wrprice Active Member
    415
    308
    Houston, TX
    Four Touring
    I found a headlight sensitivity setting in the Vehicle Settings menu of my US Four Touring. So it doesn't require a dealer visit or Carista.
    I'm not near the car, so I don't have the exact steps to get to the setting.
  7. raspy
    raspy Senior Member
    438
    699
    London, UK
    I tried it on my UK car, and can see the option to change it. Using the car's touch screen, go to setup, vehicle, vehicle customisation, light settings, and you'll see it there.
      File size:
      52.3 KB
  8. Jim in NC
    217
    266
    28
    Myrtle Beach, SC
    Thank you! I just did it. Hopefully it triggers the headlights sooner for me now.
  9. Sooner Al
    Sooner Al Active Member
    385
    340
    Oklahoma, USA
    2016 Prius v wagon
    So which way is more sensitive or less sensitive?
    RCO likes this.
  10. raspy
    raspy Senior Member
    438
    699
    London, UK
    Sadly, the manual doesn't really make that clear. Someone is going to have to experiment and post results here.
    Sooner Al likes this.
  11. wrprice
    415
    308
    Houston, TX
    Four Touring
    Positive/higher values to make the lights turn on earlier, when there's still ambient light.
    Negative/lower values to turn on the lights later, requiring more darkness.
    RCO and Sooner Al like this.
  12. Sooner Al
    385
    340
    Oklahoma, USA
    2016 Prius v wagon
    Cranked the setting one bar in the positive direction so we'll see what happens. Thanks for the help...
    RCO likes this.
