Hybrid tussle: Prius vs Civic
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by brandon, Jun 9, 2006.
  1. brandon
    brandon Member
    771
    Manhattan, KS
    Joshua Dowling, The Sydney Morning Herald
    June 9, 2006
    http://www.drive.com.au/Editorial/ArticleD...articleID=12404
    Excerpts:
    "The Toyota Prius automatically switches off its petrol engine as the car comes to rest and sits silently in traffic until the traffic light turns green, at which point it accelerates on its electric motor up to 40kmh before the petrol engine subtly kicks back into life. The genius of this system is that moving the car's mass from rest is what burns most fuel...
    Essentially, the differences are: the Prius's propulsion is primarily from the electric motor, which is then assisted by the petrol engine as required. The Honda, meanwhile, primarily is driven by the petrol engine and assisted by the electric motor as required...
    If your budget stretches only to $32,000, the Civic is a worthy proposition. However, if price is not a limiting factor, we'd go for the Prius. Toyota's hybrid system is more refined, more advanced, more user friendly and more fuel-efficient than the Civic's, which means the Prius is a better execution of its intended function."
  2. larkinmj
    larkinmj New Member
    1,996
    I test drove both cars a couple of times before deciding- the HCH and the Prius were the only contenders. HSD is a more advance system than the Honda's IMA, but they are both excellent cars and you can't go wrong with Honda or Toyota. I would tell people drive both, and decide which one appeals to you more and which meets your needs better.
  3. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Exchange rate $1.00 U.S. = $1.34 Australian.
    Some of his facts are questionable and his explanations are over simplistic but his conclusions seem valid. Can you really drive a HCH on electric only?
  4. SomervillePrius
    SomervillePrius New Member
    944
    Somerville, MA
    and the priis main propulsion is not from battery... at least not for long... and the gas engine is still used to put that charge in... it is true though that the Prius can run longer with the engine off in stop/go traffic which is cool... if not an end in itself.
    long term I think Toyotas strategy is the right one, as it should lead towards extended EV mode, plug-in and hopefully pure EV. Honda's path more goes down a path of light and lighter car which seems more like a dead end.
  5. brandon
    brandon Member
    771
    Manhattan, KS
    <div class='quotetop'>QUOTE(SomervillePrius @ Jun 9 2006, 03:04 PM) [snapback]268798[/snapback]</div>
    I think the author was trying to make the distinction between a full hybrid and an assist hybrid, although he wasn't too successful in doing so. john1701a's site has an excellent description of each:
    Full Hybrid (details) (operation)
    Assist Hybrid
    Kudos again to john1701a for his work on these documents!
  6. kram
    kram New Member
    34
    <div class='quotetop'>QUOTE(SomervillePrius @ Jun 9 2006, 04:04 PM) [snapback]268798[/snapback]</div>
    There was an interesting article in Discover magazine a few months ago by a guy who is well known in the energy efficiency field. One of his pet peeves is that auto manufacturers appear to be missing the boat on one of the best ways to improve efficiency, namely lighten up the vehicles. Just think about where we are now. A typical car weighs about 3,000 lbs and typically hauls around a single occupant that weighs about 20 times less (ca 150 lbs). That means that the car spends about 90% of its fuel just to propel the car, not its passenger! Imagine the fuel improvements if a vehicle could be made 50% lighter. That would nearly double the MPGs! Couple that with a hybrid and the fuel savings are quite dramatic. This could even apply to SUVs -- use appropriately lightweight materials and even relatively big vehichles could be almost as fuel efficient as our smaller vehicles today with similar performance. The key to lightening up vehicles, he believes, is the development of composites such as carbon fiber, carbon nanotubes, etc. He just doesn't get why car manufacturers are not investing in these technologies.
    It seems to me that improvements need to come from a number of areas such as batteries, ultracapacitors, PHEVs, ICEs, inverters, material weight, aerodynamic drag, alternative fuels, emission controls, etc. to give us the improved vehicles we need in the future.
  7. gschoen
    gschoen Member
    343
    Chicago/Wrigleyville
    2014 Prius Plug-in
    Looking at the cost of a carbon fiber bicycle, I have no doubts why they're not making cars out of the stuff. Maybe a Ferrari someday?
  8. MikeSF
    MikeSF Member
    416
    San Francisco
    <div class='quotetop'>QUOTE(kram @ Jun 9 2006, 01:59 PM) [snapback]268852[/snapback]</div>
    I don't think anyone is missing the point, its a well known fact (look at the motorcycle). But the issue happens to be with safety. Try arguing with a rabid SUV driver ESPECIALLY one that is a parent. One of the first things they fire off is safety since people tend to have the aura of invicinibility surrounding them in the name of a SUV. You can argue capacity of storage/people, you can argue fuel efficiency but one thing they usually will not budge on is their precious safety.
    Little do they realize what they're really doing (whether they know it or not) is basically an arms escalation. smaller lighter cars while yes will have tremendous damage if you go head on is not the norm which people can't fathom, yet if you try to tell them two SUVs going head on at a similar speed they almost dismiss that fact. Then up comes the arguments of getting hit by everyone else with a SUV, or that infamous "drunk driver" that everyone seems to know someone who got hit by one or some accident they experienced where they hardly had a scratch but the toyota was crushed, etc and that's the end all be all of defenses for them and driving a huge hunk o' metal.
  9. tumbleweed
    4,067
    692
    Eastern Oregon
    <div class='quotetop'>QUOTE(MikeSF @ Jun 9 2006, 02:40 PM) [snapback]268875[/snapback]</div>
    I agree with what you say but their dedication to what they see as "safety" and protection of their offspring only goes as far as their wallet. If gasoline goes to $5 or $6 per gallon they will dump the SUVs and to hell with protecting the kids.
  10. kram
    kram New Member
    34
    I agree that safety is a concern and that many equate size and weight with safety. However, the modern car is both lighter and safer than a similar type of car was a half century ago. Going forward we should be able to engineer our vehicles to be both safer and lighter still. And if they can be big as well with similar fuel efficiency that will appeal to at least some people.
    One article I read a while back suggested that most people who purchased SUVs did so mostly so that they could see the road better -- they were higher than most cars. Now with a large portion of people driving big vehicles this is no longer as big an advantage. Would much lighter car materials incite another round of even bigger vehicles? And what would happen if vehicles could be made 50% or even 75% lighter with good fuel efficiency? Would vehicles tend toward the size of step-vans? An interesting and perhaps scary thought.
  11. Drift Motion
    Drift Motion RMS13
    178
    Pasadena/Riverside, CA
    hey i never knew the civic in australia have different headlights
    hmm, intereting
    i like the one here better :p
    but still, i like the prius better
  12. stevedegraw
    stevedegraw Member
    121
    Rented both the Honda Civic Hybrid and the Prius each for three days. The Prius had much less road noise and seemed bigger inside. Bought the Prius.
  13. Tideland Prius
    16,611
    <div class='quotetop'>QUOTE(Drift Motion @ Jun 10 2006, 02:18 PM) [snapback]269284[/snapback]</div>
    They're the JDM Civic lights and also the same one used on the Acura CSX here.
  14. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    <div class='quotetop'>QUOTE(MikeSF @ Jun 9 2006, 03:40 PM) [snapback]268875[/snapback]</div>
    Until the bloody thing rolls over.
    Until they hit another SUV or a tree. Then eveyones' dead because those things are so rigid. When they hit some like a tree the occupants end up absorbing a tremendous amount of energy. They're just deluding themselves, really. They might come out fine in a variety of accidents, but they're gonna suffer badly in similarly large variety of accidents all because of the poor design of those ridig, top heavy vehicles.
  15. Drift Motion
    Drift Motion RMS13
    178
    oh the csx is only avaliable in canada?
    is it like a high class civic?
  16. rudiger
    rudiger Active Member
    696
    45
    Cincinnati, OH
    The problem isn't so much larger SUVs or pickup trucks as it is semi-tractor trailers. If you're hit by a moving mass that large while driving a large SUV, even if it's not moving that fast, you stand a good chance of surviving.
    While my Prius is great, I'm not exactly thrilled with the prospect of being flattened by a semi on the highway. Chances of survival are likely diminished quite a bit when compared with that of being in a large SUV.
    Until semi-trailers standards are changed to make them lighter (which isn't bloody likely), it's doubtful that the push to make all vehicles lighter isn't going to go far.
  17. Tideland Prius
    16,611
    <div class='quotetop'>QUOTE(Drift Motion @ Jun 10 2006, 06:15 PM) [snapback]269345[/snapback]</div>
    Yup, it's the successor to the EL (in 1.6 and 1.7 forms for the first and second generation respectively)
    http://www.acura.ca/AcuraEng/Models/CSX/InfoNav.htm
    It starts at $25,900 for the manual Touring model (Civic EX auto tops out at $23,430)
    The Touring adds paddle shifters for the automatic, auto climate control, chrome door handles, chrome exhaust, integrated indicators in wing mirrors a leather-wrapped steering wheel.
    The Premium model adds leather, heated front seats, HIDs, ASL and a CD changer.
    The Navi model adds a navigation system and PC card reader but removes the CD changer. This model is exactly the same price as a Camry Hybrid ($31,900)
  18. brandon
    brandon Member
    771
    Manhattan, KS
    <div class='quotetop'>QUOTE(rudiger @ Jun 10 2006, 08:47 PM) [snapback]269355[/snapback]</div>
    You know, there's not a lot of good research to support that position. I think most people make a seemingly-logical assumption that bigger vehicle = more safety. At face value, that's not entirely a good assumption.
    NuShrike pointed out an excellent article by Gladwell that explores and questions the basic belief in SUV safety.
  19. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    <div class='quotetop'>QUOTE(brandon @ Jun 10 2006, 11:28 PM) [snapback]269395[/snapback]</div>
    In a collision between a large mass and a small one the large mass wins. Any advantage a smaller vechicle may have is limited to an increased ability avoiding a collision in the first place. Once metal meets metal the big dog wins.
  20. brandon
    brandon Member
    771
    Manhattan, KS
    By that logic, we should see fewer deaths of people riding in SUVs compared to those riding in smaller vehicles. Per the research presented in the article, however, we find that is not the case. All of these vehicles are being made out of the same materials. The larger vehicles just use more of them. Doesn't necessarily make them any safer.
    I'm guessing the better indicator of a vehicle's safety is how those materials are used to ensure the safety of the occupant. For example, many road race cars are fairly light and consist of a tube frame surrounded by nothing but a fiberglass body. If it ran into a wall at the track, the construction of the vehicle and the way in which the materials were used would do as much or even more than a typical large SUV to protect the passenger.
    Kind of like another saying that goes around: "It's not the size that matters, it's how you use it."
