Charging port recomendations
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Cat_Prius, Nov 24, 2016.
Tags:
  1. Cat_Prius
    Cat_Prius New Member
    Lafayette, Indiana
    I'm wanting to add a USB charging port for my Garmin nav to the little panel on the left side of the steering wheel. I'm not worried about wiring as I've done similar work in the past. My concern is getting a USB port that will pop into one of the empty slots on that panel for a cleaner look. Is that a standard size or do I need something a little different?
    I was thinking something like this, if it will fit.
  2. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    748
    Delaware
    kate harvest got one that snapped right in from ebay
  3. Cat_Prius
    Lafayette, Indiana
