Cell block two melting around terminal
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Parrish21r, Nov 28, 2016.
  1. Parrish21r
    Parrish21r Junior Member
    43
    36301 Dothan Alabama
    So I've had an up and down experience with our 06 Prius battery. I've rebuilt it 3 times all replacing cell block two. The cell melts around the back of the terminal every single time. It will last a couple months before it shorts out again. Does anyone know what the wires going to the ecu from cell block two power or as to why this keeps happening to this cell alone? I've balanced the pack out equal every time and done just as it was supposed to be done and always with new cells.(13-15 model Prius cell blocks). [/[ATTACH=full]120896[/ATTACH][ATTACH=full]120897[/ATTACH] attached is two pics of the damage.
    Posted via the [URL='https://siteowners.tapatalk.com/byo/displayAndDownloadByoApp?rid=87966']PriusChat mobile app[/URL].
  2. andrewclaus
    andrewclaus Active Member
    993
    324
    Golden, CO
    I can't see your photos.
    All the ECU wiring should be small signal/voltage detection only, and should be identical for all blocks. The wire is small enough that it would probably fuse if there were enough current to melt the module. I don't think that's the problem.
    Assume you've checked the obvious and have thoroughly cleaned the bus bar and nuts, and torque to spec? Could there be some metal pitting and you may need a new bus bar assembly?
    valde3 likes this.
  3. Parrish21r
    43
    Check that and everything seems fine. It's not swelling the cell just melting the plastic around the washer of the terminal
  4. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    This pretty much profess that it has to be bad connection between the module and bush bar. You have find the reason why, and fix it. Maybe somebody can figure out something from the picture if you can get it posted here.
  5. Parrish21r
    43
  6. valde3
    2,002
    745
    Finland
    Maybe it’s just the picture fooling me but it looks like the terminal on that module numbered 5 is at deeper level than the terminal on modules marked 2 and 6. If that’s the problem then maybe just coper washer might fix it?
  7. Parrish21r
    43
    That's what I was talking about. That cell that's marked 5 was at the same level the rest and after a month of use it threw a code saying cell block two was weak. Opened pack up to find another cell(#5) had melted over the terminal shorting that cell out. Cell internal resistance and volts matches the rest but for some reason after about month it will do the same thing
  8. andrewclaus
    993
    324
    Golden, CO
    If we can get a view of both surfaces of the copper bus and nut, it might help.
  9. Parrish21r
    43
    Both of those are clean and and clear. I just re washed them back to a smooth copper. There was a little acid but not enough for this to be happening repeatedly.
  10. valde3
    2,002
    745
    Finland
    What I meant is the physical level of the terminal in the battery module. If that is not the same as modules besides it the bus bar can’t have a good contact. Should be very easy to check with anything strait and about correct length. Remember to remove the bus bars from other end of module if you use anything conductive.
  11. Parrish21r
    43
    It was the same modules as the rest. That is where I'm talking about it melted the plastic around the terminal so it looks offset compared to the rest.
  12. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    You said module 2 each time but you show module 5 this time. Is this your 4th rebuild?
    Are you tightening the nuts onto the modules with specified torque (48 inch-pounds)? If not, that might be the reason you're
    having this issue. Never seen melting at the connection before - fascinating.
  13. Parrish21r
    43
    That cell just says 5 from swapping cells around prior to the last build. But this was the 4th rebuild all from the same issue. I thought it was possible lose connection so I made sure they were all torqued properly and everything was clean still had the same end result.
  14. jadziasman
    1,355
    487
    District 6
    Two possibilities:
    1) The newer Gen 3 modules are not compatible with your older Gen 2 modules.
    You should buy a Gen 2 module as close in manufacturing date as to the others in your pack and see if this solves it.
    2) The signal wire from module 2 to the ECU or the ECU itself is faulty. Have you disconnected
    the frame wire harness to the ECU before? If not, if you find it doesn't come out of the ECU easily then
    there's corrosion or melting inside the connection.
