Car knocks When Changing Mg2 to ICE in a hill
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by san, Nov 28, 2016.
  1. san
    san Junior Member
    24
    Sri Lanka , Colombo
    I recently ( 1 month back)changed 12v battery (after 5 years) of my 2010 3rd gen prius.and recently changed the engine airfilter. when i drive in a hill (40-45 degree slope) sometimes engine knocks and misses for a while with a heavy noise.this happens when its change automatically from electric motor to the engine. During starting of the ICE it knocks ,this happens sometimes.not always and this happens only in a hill.not always.i noticed it on display bar when ICE kickstarts it knocks.in a flat road no issues at all.fuel consumption average 23-25km per litre.egr cleaning done 30000km back.want to know when running on electric motor(not ev mode) when battery gets down to low displays 2 bars then automatically its kickstarting ICE,from where it draws power to the mg2 to rotate engine?during that first rotation of engine it knocking vibrating.it happens only in a hill(climbing 40-45 slope), the thing is, it not happen everytime once in a 100 time
    #1 san, Nov 28, 2016
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    That's what mine did before the crankshaft put a hole in the engine
  3. san
    san Junior Member
    24
    Sri Lanka , Colombo
    Thanks! Is it regarding engine oil issue?or engine oil pressure
  4. tankyuong
    1,555
    662
    Central MO
    Lack of oil change
  5. san
    san Junior Member
    24
    Sri Lanka , Colombo
    Last week changed the engine oil after 9000km,using only 0w30 mobil1 full sunthetic oil.oil changed at regular intervals.once i used castrol edge professional 0w30 full synthetic that few years ago.then again switched to the mobil1 full synthetic.always used toyota filters.oil level is ok.no burning issue can u please explain
  6. san
    san Junior Member
    24
    Sri Lanka , Colombo
    Hybrid repair center here says the issue is may be fault in battery pack
  7. Mendel Leisk
    41,900
    How many kilometers (or miles?) on this car?
  8. san
    san Junior Member
    24
    Sri Lanka , Colombo
    135000 km
  9. san
    san Junior Member
    24
    Sri Lanka , Colombo
    Transmission fluid issue? This engine knock with heavy metal strucking noise comes only for a second in about 45 degree slope.at this stage car engine stalling.need some expert opinion
  10. bisco
    52,388
    have you owned it since new?
  11. Mendel Leisk
    41,900
    Purely editorial: "45 degree slope"? ;)
    Lightning Racer and Raytheeagle like this.
  12. san
    san Junior Member
    24
    Sri Lanka , Colombo
    Yes.from 2010
  13. bisco
    52,388
    do you keep an eye on the oil level between changes? are you burning any?
  14. san
    san Junior Member
    24
    Sri Lanka , Colombo
    Yes rufely 40-45 degrees.
  15. san
    san Junior Member
    24
    Sri Lanka , Colombo
    Yeah less than quarter of liter for 9000km
  16. bisco
    52,388
    that's very good, and shouldn't be a part of the problem.
  17. san
    san Junior Member
    24
    Sri Lanka , Colombo
    Thanks!
    Cant understand Why it happens only on a slope of a 35-40 degree climbing.can it be regarding engine oil circulation or a transmission oil level-circulation problem?
  18. Mendel Leisk
    41,900
    I don't think any 2 wheel drive could manage that, but anyway: it sounds like an extreme slope you have, maybe it's pushed too hard by this. Other cars use this route?
  19. Mendel Leisk
    41,900
    More like extreme stress on the whole drivetrain. I've got a roof that's 32 degrees: I will NOT stand on it, without a rope. I tried once, just broke into a sweat, had to get off.
  20. san
    san Junior Member
    24
    Sri Lanka , Colombo
    Thanks!
    Not exactly 40, may be 30-40 degree today it knocked in a car park with 30 degree angle
