noise from hybrid system
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Groger, Nov 30, 2016.
  1. Groger
    Groger Member
    70
    25
    Hi
    As per subject, 2011 Gen 3, after first winter storm of the year, car was outside. I drove 5 feet to get the snow out and noticed this high schreech noise coming from Hybrid system. turned off the car, later that morning, drove in to work, on the way in, the high schreech would come back, didn't mater if I was driving, stopped or anything. But when the engine was warmed up, I didn't hear anything anymore. Temp was 32F (0C).
    Any ideas? This car is new to me, only had it for 1.5 months now. First time I hear this, but also first snow storm as well.
    Thanks
  2. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    It's coming from the brakes.
    Hybrids, if driven correctly, don't use the traditional fiction brakes (rotors, pads) very much and rely on the regeneration braking from the hybrid motors. So, the friction brakes don't get as hot as with other cars and can develop light rust on the rotors. Using them the again after a cool down period makes for squeaks, groans, etc. Moderate braking at the next stop should clean off the light rust enough to make them quite again.
    No worries.
  3. Groger
    Groger Member
    70
    25
    That is what I thought I first as well, but it was happening also while I was driving. And it was on and off, made the sound, stopped, no wait here it is again and so forth. and it wasn't constant either. it sounded almost like you where scratching a record, pulling the needle across the record, kind off. After about 10 min of driving, it when away.
  4. fotomoto
    5,639
    3,815
    So. Texas
    Yup. Next time this happens, use the brakes fairly hard when it's safe to do so. If the issue still persists, then look elsewhere. My guess is because you're in snowy conditions, you're (wisely) still lightly braking and not getting the rotors/pads warm enough.
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    At one of your stops put it in neutral just prior to braking. This disables the regen braking and forces the friction brakes for the stopping. This will help wipe the rust off of the rotors and any sticking of the calipers.
    You may have to do this multiple times and pump the brakes.
    fotomoto likes this.
  6. Groger
    Groger Member
    70
    25
    I'm sure it also did it while the car was in park, but I will have to do more investigation.
    Thank you for your help.
  7. Mendel Leisk
    41,889
    Just for giggles, look under the car, see if anything's hanging down. There's plastic panels, maybe something got dislodged by snow? One panel in particular at the engine bay is abused by mechanics during oil changes, commonly ends up hanging down.
  8. Groger
    Groger Member
    70
    25
    Thanks everyone for your responses, I will check.
