Flat tire replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by saltdiscus, Nov 30, 2016.
  1. saltdiscus
    saltdiscus Member
    198
    89
    US
    Hi
    Sadly today is the worst day.I broke my phone screen then after and hour I hit curb with my driver side tire.my tire is completely flat and the plastic guard came out.Since these tire are new can I just replace one tire or I have to replace both the tire even if they are new.Can you recommend best all weather tire for Prius.where do I buy the black splash guard ?
  2. CNYhybrid
    CNYhybrid Member
    158
    83
    Liverpool, New York
    If the tires are brand new you should be able to replace just the one. If you are referring to mud guards check Amazon for a set of 4 from a Toyota dealer selling at a discount. If you just need the one you can try Ebay.
  3. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    +1 If they are new, match the replacement to the existing set and you will be good to go.
  4. Mendel Leisk
    41,901
    Yeah, new tires, just replace the one. The rim looks untouched?
  5. saltdiscus
    saltdiscus Member
    198
    89
    US
    Thanks guys replaced just one tire brand nexen 671 .I think I can still use the mudgaurd also but I am missing the plastic screw that holds the guard.do u know where I can just buy the screws.
  6. Mendel Leisk
    41,901
    Can you take/post a picture of the other side?
    This is a quasi aftermarket item I think?
