Gen2 JBL double disc jammed
Discussion in 'Gen 2 Prius Audio and Electronics' started by brisco, Nov 30, 2016.
  1. brisco
    brisco Junior Member
    US
    I gave up on my CD player 5 years ago when purchased 2005 model. I use the cassette adapter to a mp3 player which works fine. Just recently the disc ejection system started working at start up for about a minute then stops. Hoping someone could help me with any answers to this?
  2. cyberpriusII
    1,157
    1,795
    Mars Hotel
    For giggles, try pulling the fuse for the player. Leave it pulled for a few minutes and then re-install. Works for me when the system REFUSES to eject a disc.
  3. bisco
    52,023
    brisco? be careful now.:cautious:
    cyberpriusII likes this.
  4. cyberpriusII
    1,157
    1,795
    Mars Hotel
    Huh, I figured it was you with a pseudonym, trying not to look stupid....:p
  5. bisco
    52,023
    this is very uncomfortable.:unsure:
  6. brisco
    US
    Thanks cyberpriusll, I will try and let you know if it works.
  7. brisco
    US
    I saw your handle and thought it was me!, My GSD's name and been using it for ever. Lol
  8. cyberpriusII
    1,157
    1,795
    Mars Hotel
    Other option is to pull the 12-v negative cable, but that is more of a hassle, since you have to reset things in the car -- including disabling the reverse beep, if you ever disabled it in the first place. Yeah, fuse is easier.
  9. brisco
    US
    Neither worked, pulled fuse for a few minutes and also the neg. I ran a diagnosis on it and audio is checked, audio H/U. Memory 63-51 Occurred data time 16-11-22???. This was in System Check Mode btw.
  10. dolj
    dolj Senior Member
    8,452
    4,291
    Wellington, New Zealand
    These codes relate only to the MFD systems. 63-51 is a CD error:
    • 63-51 = Elevator Error. Mechanical Error During Elevator Operation.
    The date is Nov 22, 2016
    CD Changer: All these codes mean is to check the radio or player or the actual disc, and replace if necessary
  11. brisco
    US
    Thanks dolj, It looks like it is time for me to do a refurbished audio system. I'm worried that if I don't stick to the original unit that I'll end up with it not working with the steering controls. Just wish they made a unit w/single CD player that matched OE. Thanks again and l really appreciate this site! Everyone have a great upcoming holiday and be safe.
