Why does the Gen3 hybrid battery fail more than in the Gen2?
Discussion in 'Gen 3 Prius Main Forum' started by hasantha, Dec 5, 2016.
  1. hasantha
    hasantha Junior Member
    sri lanka
    I have noticed that the hybrid battery pack in the Gen3 Prius tends to fail more than in the Gen2. Does anyone here know the reason behind this?
    Thanks in advance.
    strawbrad likes this.
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I am not sure who is paying you to bad mouth the Prius, I wish they wouldn't. Further, I wish you had the integrity not to take their money to spread lies.
    You do not have a Gen 3 Prius.
    Consumer Reports has documented reports of vehicle reliability. PriusChat has anecdotal reports of vehicle reliability. Neither seems to indicate any large number of Gen 3 battery failures. (Gen 1 had corrosion issues, largely fixed in Gen 2.) Gen 3 is not even out of warranty here in the US, let alone near failure.
    #2 JimboPalmer, Dec 5, 2016
  3. hasantha
    sri lanka
    Hi JimboPalmer, I didn't expect such a "warm" welcome from a Priuschat member :). Insults aside, my question is a valid question that applies to the Sri Lankan market (I am from Sri Lanka, as my location tag indicates).
    My question implies that out of the Prius battery failures that have occurred in Sri Lanka (the country is over populated by the Prii), the Gen3 appears to have more battery failures that Gen2, which is strange. The overall failure is probably due to the excessive heat, dust, oxidation, etc. But I would really like to know why the older battery tends to last more than the newer Gen 3? I would greatly appreciate any theories in this regard.
    Thanks.
    strawbrad and Chet like this.
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I already gave my theory, as you know.
    I have no theories why Sri Lankan Gen 3s would have a higher failure rate than the Gen3s elsewhere in the world.
    Hypothetically, each generation of Prius has new technology that Toyota hopes will be an improvement over what has come before. Sometimes this works, sometimes the owners regret the innovation. North American Gen 2 owners found the excellent evaporative emissions control device rendered fill ups difficult and predicting range impossible. Gen 3 owners found the eco friendly plastics squeaked. Etc.
    While I know of no major changes in battery chemistries, I am not sure major mistakes would be needed. Air flow, software, sound deadening, all most any change could cause overheating in hot climates. I have no speculation why other nations would not have similar reports.
    kc5dlo likes this.
  5. saltdiscus
    saltdiscus Member
    198
    89
    US
    because srilanka has dirt and dust more than north america.:)
    Burnt_reynolds likes this.
  6. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
  7. Prodigyplace
    12,533
    11,755
    Central Virginia
  8. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    Dirt and dust would only impact the battery ventilation system, possibly blocking the intake vent. Lack of proper maintenance would allow the battery to overheat more often, and that -could- shorten life. Vacuum the intake grill to clean it.
    The GIII uses the battery more aggressively than the GII did. That could push the failure numbers a little higher, though in most places only taxi use has seen an increase in failures as far as I know.
    The GIII battery is mostly the same as the GII battery, with slight improvements.
    The battery cooling intake vent was moved from GII to GIII. Perhaps in your area the style of clothing worn is blocking it more often than in other places.
    Data Daedalus likes this.
  9. bisco
    51,851
    welcome! i can't speak for sri lanka, but 99.9% of the bad batteries reported here are all gen 2. and i suspect that is because they are older with more miles.
    if what you are seeing is actually happening (and you have no way to know, unless toyota divulged that info)
    we probably won't be able to answer your question, because it isn't happening anywhere else in the world that reports here.
  10. StarCaller
    StarCaller Senior Member
    1,277
    729
    Cedar Crest, NM, USA
    yeah right, ever heard about New Mexico? ;)
    kc5dlo, Data Daedalus, m.wynn and 3 others like this.
  11. Mendel Leisk
    41,334
    I can't recall a single 3rd gen battery failure being reported here. That, knowing my flakey memory, probably means there's been very few cases. It's a lot newer than second gen of course, but there's some high mileage cars here now, getting into oil consumption problems and the like.
  12. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Last week there was a member from Sri Lanka that had 2 issues: one on the battery side and one on the engine side. @san was the member. We helped him through the ice issues with clogging but we was talking about a steep 40%grade hill at first.
    He was working with a hybrid shop somewhere in Sri Lanka. You can check with him and get his thoughts. But this is the first I remember of a gen III battery failure.
    Data Daedalus and san like this.
  13. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    The 10-year, 150,000 mile hybrid battery warranty (California) was a huge selling point for me. The battery is one thing I don't worry about, thankfully.
  14. bisco
    51,851
    if the gen 3 is failing more than the gen 2, then gen 4 owners are probably screwed.:eek:
  15. Coast Cruiser
    2,267
    2,571
    Be nice, bisco. :eek: We are good for at least 10 years....
    (We got to get you an Avatar picture. Any man with 20 million posts should have a nice Avatar.)
  16. Prodigyplace
    12,533
    11,755
    Central Virginia
    Would this work?
    Boston Tea Party
  17. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    I offer a comment only because I was taken back by the thread heading.
    I have discussed this very issue with the Toyota Parts Manager, and he told me the only HV batteries to fail at the local dealership, have been 2nd generation Prius.
    I traded my 3rd generation (2010) Prius with 130,000 miles, and not one hint of a HV battery problem. I was unable to detect any loss in potential, and my fuel efficiency was unchanged over the 5 years that I owned it (based on detailed records I maintained every fill-up while I owned the car).
    There must be some other environmental reason as suggested above.
  18. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    What, you mean that isn't his avatar? I figured everyone else was just copying Bisco.
    #18 Redpoint5, Dec 6, 2016
    DonDNH, bisco, Mendel Leisk and 2 others like this.
  19. fotomoto
    fotomoto Senior Member
    5,632
    3,810
    So. Texas
    IIRC, there have been a few taxi drivers reporting early failures.
    There was a guy (commercial driver IIRC) who lost one very early in his Prius C. He was past warranty due to mileage but luckily found a cheap replacement from a junk yard. Found it: 2012 Prius c 221,000 miles hybrid battery dead | PriusChat
    #19 fotomoto, Dec 6, 2016
  20. KokomoKid
    KokomoKid Member
    115
    82
    Florida and Indiana
    IF the gen 3 batteries fail more often then gen 2, it could be harsher charge-discharge management, different, less robust cells, different packaging in the cars, etc. Actually, it is probably too early to have enough data to really know failure rates of gen 3 batteries.
    Data Daedalus and strawbrad like this.
