Will 14 Inch Rims Fit?
Discussion in 'Prius c Accessories and Modifications' started by HiC, Aug 29, 2014.
  1. HiC
    HiC Junior Member
    Northern, MN
    2014 Prius c
    Looking at snow tire/rim options and was wondering if 14" steel rims would fit on our C. I would like the added sidewall height of a 14.
    Was also wondering if there is an interchange chart showing what other vehicles have the same bolt pattern (4x100), offset (40 mm) and center bore size (54.7 mm).
  2. Mike500
    Mike500 Senior Member
    2,593
    767
    It would depend if the opening in the wheel clear the brakes and other suspension parts.
  3. HiC
    HiC Junior Member
    Northern, MN
    2014 Prius c
    I just found TireRack.com gives the option of ordering a 14 inch wheel/tire.
  4. Shibby
    Shibby Member
    78
    43
    Hagerstown, MD
  5. dick_larimore
    dick_larimore Member
    162
    70
    Central Indiana
    I run 185 X 65 X 15 Bridgestone Blizzak on my 2012 C4. I don't understand why anyone would drop down to a 14 inch wheel for snow tires.
  6. Davidsky
    Davidsky Junior Member
    Poughkeepsie NY
    2014 Prius c
    A narrower tire (175/70/14) cuts through the snow better. Plus the higher sidewall smooths the ride on bad roads.
  7. HiC
    HiC Junior Member
    Northern, MN
    2014 Prius c
    I want to run the Blizzak tire and I just found out that they don't make one in the 175/70-14 size. On the flip side, I have been able to find 14 inch steel aftermarket rims that fit, but no 15s.
  8. KYBlue
    KYBlue Active Member
    227
    112
    I'm running 14" steelies from tirerack with some Pirelli winter carving edge tires. They worked great and cost me no noticeable MPG last winter. My only complaint was that they were a lot noisier than the General Altimax Arctic I run on my Wife's Venza.
    Chris
  9. HiC
    HiC Junior Member
    Northern, MN
    2014 Prius c
    Ended up with 175/65-15 Michelin X-ice XI3 tires mounted on R81 Mini Cooper alloy wheels with Toyota tpms sensors.
    So far no noise or handling difference. They do pick up rocks on gravel roads though.
    #9 HiC, Oct 26, 2014
  10. Prilust
    Prilust New Member
    Ontario Canada
    Re-opening an old topic, 14 inch wheels.
    I just installed my winter wheels from my previous car(Scion iQ), they were originally off of a mid 2000 Honda Civic. I decided to test their fit on the Prius, hopeful to save my self some money. So here it is,
    185/70/R14
    CB:56.1
    I do understand that these are a bit taller than recommended, so the speedometer will be off by a bit. But they will get me through this winter at least.
  11. Mendel Leisk
    41,629
  12. dengar100
    dengar100 Junior Member
    22
    Queens, NY
    Hey there.
    Did you ever run into any issues with these? It looks like they are only slightly taller than stock.
  13. mertechperformance
    mertechperformance Active Member
    532
    126
    Nor-caL
    MOST but not ALL 14's will fit. need to figure out dish, offset, etc etc etc.
  14. dengar100
    22
    Queens, NY
    FYI I just installed 14" rims with 185/70r/14 with Xice3 tires on a 2013 Prius C and everything fits fine.
    Prilust likes this.
  15. Prilust
    Prilust New Member
    Ontario Canada
    No rubbing, no noticeable change in fuel economy, everything seems to fit fine. I'm happy overall with these. 17 hour Roadtrip (one way) coming up soon looking forward to seeing how economy and rid quality is for long distance.
