Dangerous Driving Technique: Have you tried a rolling restart?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Pluggo, Dec 1, 2016.
  1. Nougatti
    Nougatti Member
    119
    59
    Norway
    No PiPs before 2012 anyway.
    Prodigyplace likes this.
  2. Nougatti
    Nougatti Member
    119
    59
    Norway
    If you switch the ICE off right after it's started, you can risk THIS happening, especially in colder times of the year.
    I live at the top of a hill and have learnt to always coast in Neutral to the bottom to avoid the ICE kicking in.
  3. ETC(SS)
    6,586
    Note to self:
    Never buy a used Prius......
  4. fuzzy1
    10,272
    There is enormous commonality between PiPs and non-PiPs of that era, including the 'stab 3 times' method of shutting off power in regular Liftbacks from 2012 onwards. Because of this, we should make certain that drivers of older Liftbacks, up through 2011, don't mistakenly take this as a feature of their cars.
  5. Prodigyplace
    Prodigyplace Senior Member
    11,701
    11,321
    Central Virginia
    They should not be looking in a PiP forum that clearly states 2012 - 2015 then.
    Nougatti likes this.
  6. fuzzy1
    10,272
    (1) 'New Posts' throws all forums together;
    (2) Why not? Most of the subject matter is shared. I see no reason to keep the tribes so separate that they remain ignorant of the lessons learned by the others, so must discover or learn shared issues independently.
  7. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    225
    Harrisburg, PA
    Problem with rolling start is, you have to step on the brake pedal to enter "Ready" mode so you're slowing down also. And there is no steering wheel lock on the PiP.
  8. Nougatti
    Nougatti Member
    119
    59
    Norway
    What?! This I have to try tomorrow!
    iPhone ?
  9. trentofdestiny
    1,104
    225
    Harrisburg, PA
    Yeah man. It has no assist with the ignition off but you can muscle it. For the curious: it uses a standard "manual" style rack & pinion with a 80's-power-window-motor-sized motor on the column for power assist.
    iPhone ?
  10. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I'm going to go try it out right now!
  11. fuzzy1
    10,272
    When rolling, it doesn't take much muscle at all. Parked, it does take muscle, but less than on my previous power steering cars.
