GPS Question
Discussion in 'Gen 2 Prius Main Forum' started by monkeypox, Jun 10, 2006.
  1. monkeypox
    monkeypox New Member
    40
    Hi
    Hey does the GPS readout ever change from 300 ft? I drive 60 miles to work and it stays the same. and that is across diff states. just wondering.
    Thanks
    monks
  2. 8AA
    8AA Active Member
    550
    62
    Maryland
    If you're referring to the "300 ft" that appears on the map, that is just a bar scale for the current map setting. Press the "+" button to zoom in closer or the "-" button to zoom out.
  3. daniel
    14,487
    1,519
    Spokane, WA
    My Garmin Street Pilot automatically changes scale depending on the distance to the next turn. I can override that with the + and - buttons.
    You may have a setting option to turn automatic scaling on and off.
  4. qbee42
    3,079
    As said in the previous post, it's just the map scale, not the GPS error or DOP info. It only changes when you change map scale.
  5. monkeypox
    40
    Got it thanks all :)
