What's this little black box?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Max Camacho, Oct 8, 2016.
  1. Prodigyplace
    12,621
    11,805
    Central Virginia
    Does your car have the shark fin antenna? If you don't it might be a radio antenna.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    It's got a shark fin - I presume an antenna.
  3. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    My plain Three model only has the little skinny box, to the left in your photo. And no exposed wires, or wires imbedded in the windshield. Thanks for the nice pictures. I wonder how do you know when that little box is working? Does the AC have to be turned on? And does the AC have to be in the auto mode? I've never seen anything different happen in my car.
    (Many Prius owners don't like to run the AC. They may never know if the humidity/fog feature is working or not.)
  4. Coast Cruiser
    2,267
    2,571
    Yep, we all got the "Jaws fin" on top... You can see mine in the picture.
  5. alanclarkeau
    7,045
    7,593
    No idea - I thought it would be in AUTO mode.
    Prodigyplace and RCO like this.
  6. eric1234
    eric1234 Active Member
    392
    201
    Hamden, CT
    Here's a guess for you:
    Have you ever noticed that if you set your climate control to Auto, that under certain circumstances, it will change from delivering the air flow to the floor vents only to a mix of the floor vents AND the defroster? My guess is that this sensor plays a role in that decision.
    My guess (I don't monitor the A/C current with a scan gauge, but it could be used to confirm) is that when the above happens, the compressor is activated to dry (reduce the humidity level) of the air. (I believe that this also happens when we press the Defrost button).
    Just a guess, but fairly consistent with observed behavior...
    alanclarkeau, RCO and Coast Cruiser like this.
  7. Prodigyplace
    12,621
    11,805
    Central Virginia
    I do not have that on my Trim Two. Just the black dots.
    alanclarkeau likes this.
  8. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Hmm, I got those straight wires in the screen like Alan, but never remember to look for the little black box!
  9. Prodigyplace
    12,621
    11,805
    Central Virginia
    I have the US base model. That may be the difference. Perhaps somebody with a US Trim 3 or 4 can check.
    alanclarkeau and RCO like this.
