Is it normal for rear windshield to break on its own????
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jafa, Dec 9, 2016.
  1. Jafa
    Jafa New Member
    Houston, Texas
    IMG_0021.JPG Yesterday, I cane home to see that the rear windshield shattered from the corner.it seems to be around $500 expense to fix it.
    We have recently moved in this new neighborhood. I have had either flat tires or low air pressure about six times over the last 6 months. Initially, I thought it was because of old cars, but now I suspect it maybe someone from the neighborhood. I thought of posting this pic on this forum of broken windshield before getting to any conclusions.
  2. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    Anything is possible, suggest you get a security camera/game camera.
    Bluegrassman likes this.
  3. les.warden
    les.warden Junior Member
    22
    Central illinois
    Never came across forum comments about Prius windows shattering on their own. With the "other" events going on, security camera or giant dog on looong leash might be in order.
  4. JC91006
    JC91006 Senior Member
    16,795
    8,589
    I always blame my ex
    padroo and Mendel Leisk like this.
  5. ETC(SS)
    7,262
    Hmmmm.....
    You don't have a Fuelly siggie at the bottom of your post, so you might not be one of "those" Prius drivers who like to serve as a rolling impediment to normal traffic flow.
    What this means is that I've never seen automotive glass shatter without a little help.
    Sometimes, the "help" hard to isolate.
    I've seem glass shatter from lawnmowers, road rocks (yes...even the rear) even falling bullets....... because some people have this weird idea that rifle rounds can reach escape velocity.
    Weather can do it.
    Aaaaaaaand let's face it....
    You're in the Republic of Texas.
    Sometimes?
    It's not random.
    If lots of things are happening to your car you may need to take stock of your driving and employ some security measures.
    People who aren't wired to spec will often lash out at things that piss them off.
    There are a lot of signs in Texas that say: "Drive friendly - the Texas way." which always used to baffle me until I had to drive there more regularly.
    The "Don't Mess With Texas" signs are more apt, but were meant as an anti-pollution message rather than a statement of policy towards other drivers.
    Take a look at how you drive, and where you live....if you've ended a relationship badly....or have political stickers on your Bumper.
    Houston can be rough in some spots.
    Game cameras are cheap.
    #5 ETC(SS), Dec 9, 2016
    pilotgrrl likes this.
  6. Mendel Leisk
    41,703
    Looking at the picture, it doesn't seem to have been hit. I get the sense some stress built up, where it's bonded along that edge, causing it to break??
    Jafa likes this.
  7. Jafa
    Jafa New Member
    Houston, Texas
    No exes. No bad relations with anyone. No stickers on the car. This car doesn't get on the road much. Our neighborhood is somewhat secluded. Should I report this to the cops?
  8. Stevewoods
    Stevewoods Senior Member
    662
    1,172
    Seattle, WA
    It's not the type of damage that would be caused by someone with bad intent (although, of course, anything is possible).
    Mendel's comment makes most sense.
    Is this a vehicle you purchased new, in 2004?
    Tires, meh, I have personally experienced, as well have read other accounts that the wheels of the Prius can lend themselves to lost air more than others. If your tires are slashed or the valve stems pulled, that's a different dog.
    Seems like a string of bad luck.
    Police. If you are extremely lucky, they might send someone to take a report, or tell you to come in to make one. Odds are, even in my low-crime area, they will nicely tell you to screw off.
    Jafa likes this.
  9. fuzzy1
    10,529
    I've seen several posted here during my tenure on PC. But this does seem to be quite infrequent.
    I did witness it once, in 100 degree temperatures in a climate where that is uncommon.
  10. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    It's extremely unlikely for glass to break on its own. If it had a crack, the cold weather will often cause cracks to creep further, but I've never seen a windshield break like that from cold weather. To me it looks like your car was hit by an object in the lower left corner.
    It doesn't look like it was a malicious attack on your windshield as this would be an unlikely place to hit it, if that were the intent. More likely is something like a kid with a baseball who hit it there accidentally.
    Jafa likes this.
  11. MrMischief
    MrMischief Active Member
    426
    443
    Denver CO
    It's fairly common for sunroofs to do this. I don't see why the rear glass in the hatch would be any different. Could have just been weather and I'd try to just chalk it up to that rather than stress over it.
  12. Jafa
    Jafa New Member
    Houston, Texas
    I am the second owner. I know the first owner and bought from her years ago.
  13. Jafa
    Jafa New Member
    Houston, Texas
    I have found a guy who can replace the windshield for me? Any ideas where I can buy the windshield for a better deal?
  14. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    Try this salvage yard. It's in Houston.
    Jafa likes this.
  15. stockdaddy
    stockdaddy Member
    208
    56
    Missouri
    The glass may have already had a chip or small crack in it which is cause it to break on its own at some point.
    I had an oil change done to my car and by the time it was done my front windshield was broken. Luckly the car shop repaired it for free.
    Another time i drove 100 miles and watched a small crack on the front windshield grow in size by over 12 inches during the trip.
  16. bisco
    52,121
    welcome! be glad it's not a prime.
  17. JC91006
    16,795
    8,589
    Broken by road debris? Insurance will pay
  18. Jafa
    Jafa New Member
    Houston, Texas
    Thank you all!
  19. archae86
    archae86 Member
    153
    24
    Albuquerque, NM
    In the middle 1960s my father was working from an office in Denver but very frequently visiting a preproduction facility on the western slope. He reported having the rear window fracture on a rental car twice. On both occasions it was extremely cold and the window shattered shortly after he crested a ridge when the cold soaked window was suddenly hit by sunlight.
    This particular mechanism seems not likely in the case at hand, and it well may be that modern automotive window glass differs in some important way, but I thought I'd mention it as a case of not quite spontaneous window fracture.
  20. ETC(SS)
    7,262
    I still think that this is anthropogenic.
    We had a Prius in a larger town suffer a broken rear hatch glass shortly after I responded to this thread.
    As a matter of fact, it looked very much like the OPs picture.
    Ours wasn't a case of "Prius Hate" but rather it was a disgruntled customer....or a bored teenager.
    The indicator was a large rock that was found in the cargo bay.
