For Sale Snow Tires Mounted to Prius Rims - Minneapolis Area
Discussion in 'Private Sales' started by craigk, Nov 15, 2016.
  1. craigk
    craigk Member
    139
    Golden Valley, MN
    Prius OEM rims with Nokian Hakkapeliitta RSi snow tires, size 185/65R15 M+S. Used on a 2007 and 2011 Prius (wheels should fit model years 2003-2015). Includes TPMS sensors if you want to use them and have them programmed to your car.
    The wheels were painted black but can be returned to original.
    $500 obo
  2. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    Any pics? What year did they come from originally? What year(s) do the sensors work for? Thank you
    iPhone ?
  3. craigk
    craigk Member
    139
    Golden Valley, MN
    Having trouble uploading pics, PM me with email and I'll send to you. They were originally off a 2007 and the sensors most recently were used in a 2011 (I said 2010 originally).
    #3 craigk, Nov 15, 2016
  4. craigk
    craigk Member
    139
    Golden Valley, MN
    Snow is here! Price lowered to $375.
  5. Mendel Leisk
    40,919
    FWIW, the TPMS valves will work fine even if not initialized.
    @craigk maybe you should post the tread depth?
  6. craigk
    craigk Member
    139
    Golden Valley, MN
    The tread wear monitor says 4 (scale is 4/6/8).
    Mendel, according to what I have read, the TPMS sensors need to be programmed to each specific car in order to report air pressure correctly.
    This is what I have read for 2006-13 Toyota Prius: "When a tire pressure sensor and/or tire pressure monitor ECU are replaced, the sensor ID must be memorized (registered) by the tire pressure monitor ECU prior to system initialization. To perform this procedure, a Toyota Techstream must be used."
    If this isn't the case please let me know.
    Thanks.
  7. trentofdestiny
    1,104
    227
    Harrisburg, PA
    I think he just meant they will hold air
    iPhone ?
  8. Mendel Leisk
    40,919
    Yeah, basically what I'm saying: tpms on snowtires, at least for me, is a moot point. It doesn't make them more or less attractive. If I was building my own snow tire package there's no way I would shell out extra for tpms, and then be locked into the dealership for twice yearly initialization (or invest in expensive equipment and braincell study of diy initialization). But if they've got tpms, s'okay, just would install them, air them up, and ignore the light.
    But that's in Canada. In the States, maybe you have to pass some safety inspection?
    trentofdestiny likes this.
  9. trentofdestiny
    1,104
    227
    Harrisburg, PA
    I'm too OCD to have the tire light on lol. And it doesn't hurt I have the equipment to program the TPMS.
    iPhone ?
  10. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I currently have my winter wheels (steelies with Blizzaks, no TPMS) on the car, and I notice when I park in my garage where the summer wheels (with TPMS) are stored, the NagLight stops flashing, only to start again later when it realises it is not near the wheels with the sensors. The really curious thing is that in the good weather I seldom use my garage, but the parking spot I use is about 30' higher and about 400' (in a direct line) away from my garage, and if the car has been parked overnight, when I start the car, the TPMS NagLight stays off, but starts flashing after 20 mins or so of driving! I didn't realise the TPMS transmitters had such a long range! (…might be some really weird ducting going on I suppose… o_O)
  11. Mendel Leisk
    40,919
    Hey, just drive around with the OEM tires in the hatch. :)
    We did have for wheels in the back today, getting new tires on loose rims (our son's car). It's a very versatile car.
    Just realized: hijacking OP's thread, sorry.
  12. craigk
    craigk Member
    139
    Golden Valley, MN
    I never had any TPMS sensors when I used them, I just ignored the tire pressure light when it occasionally went on (the summer tire sensors in the garage kept the light off unless I drove a long way). A friend installed the TPMS sensors when they had a dealer swap the summer/winter wheels, they said they legally were required to do it.
  13. WilDavis
    2,493
    2,155
    49
    I like that idea, and if my State Inspection were due in the winter, I would do just that, but the car is inspected at the end of June (my birthday (NH)) and at that time the summer wheels are on and all the TPMS NagWare is happy!
  14. Mendel Leisk
    40,919
    So will they ground you if the tpms is not functioning?
    Again, @craigk is trying to sell some tires here, I've done it again. And it seems a good deal, especially with OEM rims.
  15. WilDavis
    2,493
    2,155
    49
    I would argue that when the car is in, or parked in the proximity of my garage, or when the summer wheels are in the back, the TPMS system is most definitely functioning!
  16. trentofdestiny
    1,104
    227
    Harrisburg, PA
    In PA, the TPMS light is NOT required to be off for safety inspection. Additionally, if the car comes to the dealer with the light on, they aren't required to fix it, but if it comes in with the light off, and they do tire/wheel service, then it must leave with the light off. I think that applies to the whole country (T.R.E.A.D. Act).
    iPhone ?
  17. craigk
    craigk Member
    139
    Golden Valley, MN
    Agreed.
    Tires/wheels sold.
