Red warning light and check engine light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by HHS, Dec 11, 2016.
  1. HHS
    HHS New Member
    Long Beach, CA
    Have a 2004 Prius gen 2. Red warning light and check engine light came on while driving on the freeway. Changed the oil a week ago. What could this be?
    iPhone ?
  2. Prodigyplace
    12,521
    11,742
    Central Virginia
    First, welcome to Prius Chat.
    You likely need your dealer to read the trouble codes to really have a good guess. Report the codes back here and let the troubleshooting begin!
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Check the engine oil level and make sure its not super low.
    Then check the Invert Coolant pump operation by removing the Inverter coolant tank cap and with a flashlight look down into the reservoir and see if the fluid is bubbling or has good turbulence while the car is on. If not the Inverter Coolant pump has failed and must be replaced. very very common.
    If engine oil level is correct and not super low and you have good turbulence in the Inverter fluid it could be many other things. Its a Master caution so its not kidding. Get the codes read asap.
    There was a technical Service Bulletin out for the pump I'm hoping your car has seen the dealer in the last few years and got the free pump.
  4. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    And how's your 12V battery?
  5. HHS
    HHS New Member
    Long Beach, CA
    Can any of you recommend a good Prius person near Long Beach, CA?
    iPhone ?
  6. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    This has happened to me several times. Red triangle comes on with drippy oil can symbol and goes off immediately. Oil level always fine. Once, my wife drove with red triangle on from the start. She got 1/4 mile from home and said it shut down. When I got there, all was fine. Perfectly normal operation. She didn't observe the problem screen. Dealer found lots of codes, said most involved cascading--one led to another, etc. Suggested replacing injectors at $1000. Had replaced coils at $900+ to try to fix another check engine light problem. Coils were one of the codes stored. No thanks. Car has 150k and no observable problems. No check engine, no triangle. I'm NOT saying to ignore problem, but the codes don't necessarily suggest right action, at least not in my case. I'm no expert, just my two cents.
    I wouldn't object if someone suggests deleting my post and someone else does do. Anecdotes aren't reliable means of solving problems.
  7. 05PreeUs
    05PreeUs Senior Member
    1,097
    564
    MSP
    I actually get this combined with beeping when the key/fob is too far from the dash, it goes away when I put the key closer to the slot.
  8. Prodigyplace
    12,521
    11,742
    Central Virginia
    So, perhaps a weak key fob battery?
  9. 05PreeUs
    1,097
    564
    MSP
    If that does not happen with the key in the slot, I would try a new one.
    Prodigyplace likes this.
  10. JC91006
    JC91006 Senior Member
    16,761
    8,562
    This is nonsense.
  11. HHS
    HHS New Member
    Long Beach, CA
    Error code was P0A93
    iPhone ?
  12. HHS
    HHS New Member
    Long Beach, CA
    iPhone ?
  13. HHS
    HHS New Member
    Long Beach, CA
    Got the error code today. Error code was P0A93
    iPhone ?
  14. JC91006
    16,761
    8,562
    The easiest and best code you can hope for. Your electric inverter pump needs replacing.
    HHS likes this.
  15. HHS
    HHS New Member
    Long Beach, CA
    Thank you!
    iPhone ?
  16. HHS
    HHS New Member
    Long Beach, CA
    Thank you!
    iPhone ?
  17. Prodigyplace
    12,521
    11,742
    Central Virginia
