What Radio Aux-In products are Currently Available?
Discussion in 'Generation 1 Prius Discussion' started by Pri-Eye, Nov 2, 2016.
  1. Tape & AM/FM Radio
    33.3%
  2. 6-Disc Changer
    0 vote(s)
    0.0%
  3. Aux-In/iPod
    0 vote(s)
    0.0%
  4. Bluetooth
    66.7%
  5. Satellite Radio
    0 vote(s)
    0.0%
  1. Pri-Eye
    Pri-Eye Junior Member
    34
    Metro Detroit
    2001 Prius
    I'd like to add an Aux-In to my Classic.
    Does anyone know what options are currently available?
    Are there any plans online to solder your own input board?
    I'm not even opposed to adding an amplifier if need be.
  2. ChapmanF
    15,467
    Not sure if you can still get a DICE I-Toyota-R these days, but that's what I put in my Gen 1 back in the day, provided an aux in and also an iPod interface. I had to make a few mods to the wire harness that came with it, described in this thread. Keep reading the thread down to the post that says SUCCESS. :)
    Hope that helps,
    -Chap
  3. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    Connecting an Ipod or Iphone to my 2003 Prius - All It's all there. Doesn't need to be an Iphone or Ipod, even. I guess I'd just add a USB port instead of all the goofy power stuff. It would be nice to disassemble the radio itself and solder the aux to the cassette input on the main board. Never use the cassette, ever. I don't even own any cassettes. Too much disassembling for me, tho.
    A little comment, even my 01 Taurus has a standard CD player. Cassettes were already dead when Toyota spec'd these radios. What the heck were they thinking? would have been nice if they'd used a standard 1 din radio, too. Proprietary radios are just plain stupid.
  4. Pri-Eye
    34
    Metro Detroit
    2001 Prius
    Has anyone installed the WT-AUX found all over eBay? or the PA20-TOY?
    Is the 3.5mm Input Pre-Amped (Line Level)? I'm assuming not.
    Anyone know of any online videos showing the menu navigation?
    I have the 6-Disc Changer and factory nav installed currently.
    Ideally, I would like the Navigation to still be able to interrupt the music.
  5. Pri-Eye
    34
    Metro Detroit
    2001 Prius
