2010 AC not working on days when temp is under 60 F
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by hornedfrog, Dec 16, 2016.
  1. hornedfrog
    hornedfrog Junior Member
    32
    I noticed that my AC was not working today. It is 59F here, is that a "feature" to save fuel?
  2. JC91006
    JC91006 Senior Member
    16,780
    8,575
    You are looking for colder than 59f air?
  3. hornedfrog
    32
    Just curious as to why it didn't blow cold.
  4. JC91006
    16,780
    8,575
    What temperature do you have the climate control set at? If it's more than 59F, then it'll blow warm air
  5. hornedfrog
    32
    It is set on Low. Usually, it blows cold all of the time on Low.
  6. qdllc
    qdllc Senior Member
    1,377
    400
    The Prius hot/cold baffle moves based on the temperature you have set. On the 2013, if you go as far down as it will go, it will always try to keep cooling. When set at a specific temperature, it heats or cools based on what it's reading the inside temperature to be.
    If it never happened before, something has changed, but it's normal to maintain the set temperature.
  7. hornedfrog
    32
    Thank you it is unusually warm today so I will test it out again I have never have the service to the AC on this 2010.
  8. Mendel Leisk
    41,628
    I would think with ambient temp around 60F and cabin temp set to LO, the AC should still blow good and cold. It'll refuse to run the AC compressor, but only when temps are much lower, around freezing.
  9. hornedfrog
    32
    Thank yo. It is working now but doesn't seem to work below 59 very well. It blew cold on a warm day, do I have gremlins?
  10. Mendel Leisk
    41,628
  11. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    It always works for me on my 2012 Plug-in, but maybe the compressor itself had become too cold or maybe your traction battery's state of charge was too low? From your description, it's not something I'd worry about, though I'm not an hvac expert at all.
    I used to use my AC in "low" California winter temps as a windshield defroster. I moved to a place with a garage, so I rarely do that any longer.
  12. qdllc
    qdllc Senior Member
    1,377
    400
    Have your coolant system checked. Refrigerant leaks out over a period of time (trace amounts here and there), and after 5 years of ownership, you should take it to a trusted shop to have them "top off" and make sure it's working okay. If it takes a serious amount of refrigerant, you might have a leak somewhere. Most all current A/C systems are designed to stop using the compressor when there is a system problem, but insufficient cooling is the first sign of a refrigerant loss (natural or otherwise).
    hornedfrog likes this.
  13. hornedfrog
    32
    Thank you.
