KWh/ Mile? Justifying 19 cent KWh electric rate
Discussion in 'Prime Plug-in Charging' started by kearsarge, Dec 12, 2016.
  1. Rmay635703
    Rmay635703 Senior Member
    2,668
    1,687
    Somewhere in Wisconsin
    2013 Chevy Volt
    Like I told the 100mpg in traffic guy, a prime will probably hit 60 miles range hypermiling like he does already deflating the too expensive electricity argument
  2. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    It's really hard to hyper-mile when you are traveling at a steady 70mph speed on the highway. Nothing you can really do except draft.
  3. bisco
    51,895
    idk, i can't even hit 20 miles hypermiling. and i'm not that interested since you can't really take advantage. but i can get 15-16 around town in good weather, and would love to know what prime can do.
  4. Rmay635703
    2,668
    1,687
    2013 Chevy Volt
    Do you drive 70mph into your parking space?
    Given the limited range of the prime and the fact it's about the same price as a normal prii,
    I have to guess you can use the primes ability to switch to electric at will in any driving situation where you are slowing down, going downhill, stopped or driving off the highway.
    I'm certain you have at least 5 miles during a typical drive that you could command electric and save energy doing so. The longer your drive the more opportunity there is.
    Aka you could use electric whenever it is most economically feasible on the road or when gas price goes up.
    On my volt I can get about 10% better mpg on 1000 mile trips where I can't plug in gaming the ability to shut the motor anytime I expect a "low power" situation.
    Add to this unless you only keep your cars only a year I fully expect gas to start climbing in price in the not so distant future, the rather small investment to have a better car like the prime is worth it even if you never charge it.
    The prime should also allow for better preheating capability than a normal prii and is likely just a better car.
  5. Lee Jay
    5,850
    4,036
    What are you talking about? The topic was all-electric driving range.
  6. Rmay635703
    2,668
    1,687
    2013 Chevy Volt
    The topic is about 19 cents a kilowatt pricing and how to justify it.
    Your argument is faulty because there is no reason to own a phev if you don't plan on burning gas.
    With a prime you have the choice of using the fuel most appropriate to save you money.
    For example in the winter it might be cheaper to run electric because gas mpg drops to 40ish
    Your belief you only run one or the other for comparison is faulty.
    Furthermore when you run ev you don't have oil and filter changes, there are costs beyond your simplistic comparison and fuel prices today are unstable.
    The only reason to own a prime is because it gives you a choice of fuel, otherwise just own an ev.
    Further that the prime is no different in price so you could just run it as a gas car
    breakfast and EV-ish like this.
  7. Lee Jay
    5,850
    4,036
    This is why I hate non-threaded forums. Here's the discussion you missed:
    #67 Lee Jay, Dec 16, 2016
  8. Tideland Prius
    16,553
    Food for thought.
    I wonder if the difference between the two charges (6.3kWh and 6.7kWh) is that those two people charged from a different start point.
    i.e. One charged when the EV portion of the battery was almost done or that the car just went into the HV portion, the equivalent of "8 bars" in a regular Prius. (6.3kWh)
    The other charged it once the car was already into HV mode (the equivalent of "6 bars" in a regular Prius).
    breakfast and bisco like this.
  9. bisco
    51,895
    if it's like the pip, it's just like the lift back. once you're into the hybrid portion, the ice fires. after that point, you could be charging anywhere from 8 green bars (if you pulled up to the charger when the ice came on) yo 2 purple bars if you ran it all the way down.
    how many kWh between the two?
  10. Prius Maximus
    Prius Maximus Senior Member
    955
    810
    Northeastern IL
    I'm not going to sweat the details over a few cents/kwh. the way I look at it, regardless of the cost of electricity (within reasonable residential rates), I'd rather spend my money on electricity made in the US than on gasoline from big oil or a terrorist nation....
    3PriusMike and bisco like this.
  11. bisco
    51,895
    one of the many reasons i'm in the game.
  12. El Dobro
    El Dobro A Member
    7,088
    3,270
    Just the pleasure of extending the time between visits to the gas station is worth whatever I'm paying for electricity ( currently less than .16/kwh). ;)
  13. MikeDee
    MikeDee Senior Member
    1,580
    597
    San Francisco Bay Area
    So you buy a car that is 100% made in Japan, putting Americans out of work. With the advent of fracking, this concept of being beholden to a despotic middle eastern country for imported oil is out of date.
  14. EV-ish
    EV-ish Active Member
    602
    278
    SW US
    Not out of date at all.
    Oil is fungible. The origin does not matter, the price does.
  15. Neohippy
    Neohippy Active Member
    220
    201
    Clearwater,Fl
    2013 Prius Plug-in
    I'm a production manager for a company in the aviation industry. We have more workers from other country's then we do the United States. We take applications from anyone. As much as I hate to say it the average American worker is lazy and feels entitled. It's Americans to blame others are taking their job not other country's. Maybe if American cars were built better more people would chose them over the Japanese.
    Rmay635703, KrPtNk and bisco like this.
  16. Lee Jay
    5,850
    4,036
    If Americans ever start building decent cars, I will buy one.
    We produce about half of the crude we need for refinery inputs.
  17. bisco
    51,895
    maybe we can put the out of work coal miners on a nice healthy assembly line job.
    Bluegrassman likes this.
  18. Prius Maximus
    955
    810
    Northeastern IL
    If an american car was built as well and as efficient, I would buy one. Seems you're not opposed to putting americans out of work since you also own a prius. I am opposed to fracking. I am opposed to burning gasoline as a fuel. But until BEVs can replace an ICE for my needs and the infrastructure is sufficient, I'm stuck buying the most efficient car I can.
    mertechperformance and KrPtNk like this.
  19. JasonG
    JasonG Member
    71
    San Francisco, CA
    The most I've had to charge is 6.27 kWh based on the chargepoint charger at my work with a completely depleted battery and car has switched to HV mode.
    I get >25 miles per charge in city plus stop and go highway. Pure highway at 70 mph seems <20 miles so HV likely the way to go on the highway...
  20. EV-ish
    602
    278
    SW US
    I gather that gasoline is ~ $3/gallon in SF, so at 70 mph you are paying about 6 cents a mile in HV mode.
    By your reckoning, 6.27 kWh of electricity pushes the car about 20 miles on the highway at 70 mph, so you are getting ~ 3.2 miles per kWh.
    Equal fueling prices then would be 6*3.2 = 19.2 cents a kWh
    #80 EV-ish, Feb 2, 2017
