Real World MPG Numbers
Discussion in 'Gen 4 Prius Fuel Economy' started by krmcg, Jan 22, 2016.
  1. sgpriusdriver
    sgpriusdriver New Member
    22
    Singapore
    I find that the higher octane/priced fuel feels less rough and less noisy when you ram the prius engine up a hill. On normal roads, there isn't much of a difference in terms of feel. But at 14% higher cost, the 12% better mpg might or might not be worthwhile?
    Esso Supreme vs Esso Extra
    RCO likes this.
  2. Mendel Leisk
    41,873
    I really doubt going up an octane grade is going to gain you any mpg improvement, let alone 12%. That'd be all over the news, lol.
    RCO likes this.
  3. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    275
    Harrisburg, PA
    You are NOT getting 12% better mileage on premium fuel. Any difference you are seeing is due to other factors. This has been tested and retested by SAE and others.
    RCO and krmcg like this.
  4. sgpriusdriver
    22
    Singapore
    I'm not sure what SAE papers tested on what kind of car. But this is how I tested on my prius gen 4 and got my real world(basing on prius computer) mpg numbers in two separate days:
    1)Ran fuel tank til near empty.(fuel light up)
    2)Fuel up full tank at the same gas station(Reset the trip odometer) that is located just before the highway(20km) back to my home at around 5am(zero traffic). . Both temperature and weather was consistent on both days.
    3)Drove back to my home at the same cruise control setting speed of 80km/h.
    4) That's how I got to 4.1l/100km(57mpg) for Esso Extra and 3.6l/100km(65mpg) for Esso Supreme.
    #524 sgpriusdriver, Dec 18, 2016
  5. Mendel Leisk
    41,873
    Just for reference:
    (From Esso Canada site)
    What about Esso Regular?
    Barring other variations, say traffic congestion or whatever, I'd grudgingly say you're being methodical in your testing. Still, I'm very sceptical, for a couple of reasons:
    1. Higher octane fuel's reason for existence is to prevent pinging in the smattering of higher compression engines on the road.
    2. A 12% increase in fuel economy, and no one's heard about it?
    One variable maybe being overlooked: percent of ethanol added to the different grades.
    RCO and bbald123 like this.
  6. mertechperformance
    mertechperformance Active Member
    532
    126
    Nor-caL
    I've got almost 12k miles on my '16 eco. lifetime average is 57.6 mpg. Thats mostly 72mph highway as well.
  7. bbald123
    386
    275
    Harrisburg, PA
    You don't have enough data points to draw a conclusion. You would need to drive a measured course with several repetitions for each type of gas. You would also have to account for ambient temperature, pressure and temperature of the tires, wind speed, starting state of charge of the traction battery and a myriad of other variables to be sure that you were seeing a real difference and that difference was due to the gasoline choice.
    Of course, this is why the testing is usually done on a dynamometer in controlled conditions such as indoors.
    What you have done barely rises to the level of anecdotal evidence.
    RCO likes this.
  8. bbald123
    386
    275
    Harrisburg, PA
    Great point about the ethanol and other octane boosters.
    Mendel Leisk and RCO like this.
  9. bbald123
    386
    275
    Harrisburg, PA
    RCO and mertechperformance like this.
  10. greenmonster01
    106
    79
    Southeastern MA
    3rd fillup.Colder weather taking it's toll...
    539 miles with 9.65 gallons
    60.5 on the MFD 55.9 calculated
    RCO likes this.
  11. greenmonster01
    106
    79
    Southeastern MA
    Still bothers me that the MFD is 7.5% higher than manual calculations...
  12. Prodigyplace
    12,664
    11,828
    Central Virginia
    I am lazy. I just use the MFD as an indicator and have not bothered to compute manually.
    RCO likes this.
  13. krmcg
    2,592
    2,392
    Whittier, CA
    I get a very consistent 5%
    greenmonster01 likes this.
  14. greenmonster01
    106
    79
    Southeastern MA
    Looks like some are really close, and others (like you and me) are off quite a bit... I've been reading backwards on this thread looking for trends, but haven't found any reasoning on the delta.
    Just curious... I'm quite happy with matching the EPA combined mileage in freezing winter weather. It'll be interesting to see what late January / early February does to the numbers...
  15. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    OMG! I'm glad that I really don't care. Like prodigy, I just use the car indicator. Perhaps the discrepancy derived from the fact that cars speedometers are designed to overread the actual mph. (n)
  16. first_superior_prius
    76
    115
    Michigan
    I got a 4% initially, and since then it has been 4 or 5%, but today when I filled up the discrepancy was 10%. Wondering if the cold weather and snow has something to do with it, or if it was just this particular fill up and pump
  17. HobbsNick
    HobbsNick Member
    107
    156
    Newcastle, U.K.
    Had the car for just over 2000 miles and I'm happy with the MPG as I'm seeing it increase on each tank fill. Just got 64mpg (53mpg US) on a 300 mile round trip at 3c (37.4f) and an average speed of just over 50mph. Road mix was 60% Motorway 40% normal roads. At this time of year that's 9mpg (7.5Mpg US) more than what my Hybrid Yaris would do on the same trip. Can't wait to see what it will do in the summer, based on this comparison hopefully I'll get over 75mpg (62mpg US)
    The above figures are all based on in car readings.
    RCO likes this.
  18. inferno
    inferno Senior Member
    1,072
    405
    What temps? Amazing you guys get the Hybrid Yaris ... :O The US gets screwed out of so many options, and in 2017 we will be even more screwed (possibly)...
    RCO likes this.
  19. HobbsNick
    HobbsNick Member
    107
    156
    Newcastle, U.K.
    The temp for the 300 mile trip was 3 degrees C, when in the Yaris it was the same time of year and the temp was similar. The best mpg I got from the Yaris was 66mpg (54mpg US) when it was above 15 degrees C.
  20. inferno
    1,072
    405
    Do you guys have the Prius C model? the MPG sounds like it, maybe the Yaris Hybrid in Europe = Prius C here?
