Is it ok to power off prius during forced low battery regen?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by sgpriusdriver, Dec 18, 2016.
  1. sgpriusdriver
    sgpriusdriver New Member
    22
    Singapore
    I was at the parking lot when my battery indicator hit 2bar which began the forced noisy engine regeneration of the battery. Is it better to let the engine regen finish first before shutting down or is it ok for me to switch it off like any other car? I'm going to let the car idle for 12hours as I sleep.
  2. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    If you let it idle for 12 hours it will simply waste fuel, albeit no more than ≤0.5 gallons. Yes it will charge the battery, but it is safe to switch off the car and it will charge as required next time you use it. That assumes you are not going to leave it unused for more than a day or two.
    Welcome to Prius Chat.
  3. Mendel Leisk
    41,442
    It's fine to shut down. The car ran the battery down, due to low-speed driving, and kicked on the engine. But yeah, that happens all the time.
    We would park in the upper levels of a parking garage, and spiraling slowly up through the levels the car would invariably run electric-only, and due to the grade eat up the charge quite fast. Engine would without fail be running by the time we parked, no problem: shut down. Later when starting up, engine continues to run.
    Look at it this way too: if it was so important to follow certain behaviors with the car, they would be breaking left and right. :)
  4. sgpriusdriver
    22
    Singapore
    What I mean by "Idle" as in power off state for 12hours before switch on again. During that time I am sure the battery will also naturally discharge but I am not sure how much discharge is happening.
    I am sure Toyota has factored in some protection mechanism for it's NIMH battery, but I am thinking along the lines of how to better care for the long term life span of the NIMH battery as I understand that batteries do not like to be completely discharged or stay too fully charged.
    I park my car up a high story carpark(lots of ramps which eats up battery) too, so I don't have the luxury of keeping battery levels high before switching off.
  5. GreenJuice
    GreenJuice Active Member
    195
    127
    London, UK
    IIRC 2bars on the battery indicator on the Gen2 and Gen3 was actually about 40% HV battery State of Charge as indicated on OBDII port devices like ScanGauge II. Not sure about Gen4 as yet, but I hope to be doing some tests soon and will post on it in the New Year.
    So there is still plenty of spare charge left. Maximum bars on these earlier generations was 80% SOC, and I understand this type of aggressive battery management is needed to maximise its lifespan.
  6. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    Because of my rural location, I rarely park with more than 2 bars. Why waste gasoline forcing the battery to charge when you can be driving at the same time. During my warm-up, the battery is regularly charging at 20 amps or so at the same time I driving down the road.
  7. fuzzy1
    10,450
    If you want the engine to run while climbing the ramps, consider switching to B mode at some point while the engine is running, either during or just before the climb. I believe B will override the ICE auto-shutoff.
    At low speeds, if the ICE is initially off, B may not help trigger the ICE to turn on.
  8. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    With it in B, is it charging the battery?
    To answer the OP's question - just drive it, mine often has 2 bars when I park, sometimes the ICE is on, other times not. In SINGAPORE's heat, it's going to be an undetectable drop of charge over just 12 hrs.
    RCO and Mendel Leisk like this.
  9. fuzzy1
    10,450
    It ought to charge just as well as D mode with ICE spinning. The main point of this maneuver is to prevent the normal D-mode ICE auto-stop. It is unrelated the real purpose of B.
    Agreed on all this, the 2 bars ought not be an actual problem.
  10. bisco
    51,916
    you can't hurt your prius, shut it down anytime, drive it like a regular car. pay no attention to the man behind the curtain.
  11. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    #4sgpriusdriver, Today at 4:20 PM
    Perhaps when you're driving up these ramps to park you could use the engine more by being more aggressive with the accelerator pedal wherever possible. Not to cause a danger to yourself or others goes without saying!
    #11 RCO, Dec 18, 2016
  12. Mendel Leisk
    41,442
    That's what runs ours down too. Low speed and a grade. No matter.
