Throttle Body Booster ?
Discussion in 'Gen 3 Prius Fuel Economy' started by Scottyboy24, Dec 24, 2016.
  1. Scottyboy24
    Scottyboy24 Junior Member
    33
    Pensacola, Fl.
    Has anyone ever tried a
    Airaid 1025 Throttle Body Booster 2010-11 Toyota Prius 1.8L?
    I found it at JEGS for $19.99.
    It claims increase of 1-3 mpg and 6-10 torque.
    Please let me know if you know anything about this and if it could really work or not?
    Thanks,
    Chris
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    If Toyota could legally advertise 3 MPG more for only a $20 investment per car, they would.
    Scottyboy24 likes this.
  3. bisco
    52,286
    i say give it a shot and let us know.(y)
    Scottyboy24 and Raytheeagle like this.
  4. Prodigyplace
    12,627
    11,808
    Central Virginia
    I would wonder why just 2010-2011? I believe all models since then, except for the Prius c, use the same size engine. The Gen 4 has improved efficiency, but it is still 1.8L.
    Was there an engine design change in 2012?
  5. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Stop looking for miracles. There aren't any.
    This is snake oil. Don't waste your money.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    It says on Amazon it will fit a 2015 Prius 2 (didn't check all models as the 1.8L is common).
    So if you are curious (and this a relatively low cost test), give it a shot and keep us updated(y)
  7. Neohippy
    Neohippy Active Member
    220
    201
    Clearwater,Fl
    2013 Prius Plug-in
    If this was beneficial it would be implemented on many cars. A lot of research goes into air box design and intake manifold design. Not worth it IMO
  8. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Possibly NSFW.
    Scottyboy24 and Neohippy like this.
  9. Bham_prius
    Bham_prius Junior Member
    35
    bellingham
    You should get the magnets for your fuel line too ;)
  10. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    There actually are benefits to adding turbulence to the intake stream... if it's controlled, and actually happening in the cylinder. That's what Toyota's done with the Gen 4's engine, as well as the new Dynamic Force engine for the next-gen Camry.
    Adding it at the throttle body won't help.
  11. Scottyboy24
    33
    Pensacola, Fl.
    Thanks to everyone for the replies.
    So I will pass on the snake oil, but what about the $200 ram air intake system? Would it be worth the $200 in the long run? I am about to replace the air filter anyway and planned to put in a $50 K&N, so really I would just be putting down another $150.
    What do ya'll thank?
  12. Scottyboy24
    33
    Pensacola, Fl.
    Oh and for those that say yes to the aftermarket intake system, which one of these should I go with?
    Injen Short Ram Air Intake System
    • or
      HPS Shortram Air Intake Kit + K&N
  13. Scottyboy24
    33
    Pensacola, Fl.
    Oh thanks dude, but I don't think I need one of them. I use unleaded gas! hehe ;-)
  14. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  15. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    Neither of those are even actual ram air systems. A true ram air system would involve a scoop somewhere, and cutting a hole in the hood or bumper for it, the idea being that the car's motion through the air will ram air into the intake manifold, increasing power.
    That is what is commonly referred to as a "cold air intake", although that's also a misnomer. Your stock induction system is, as far as I'm aware, an actual cold air intake, it'll have a duct to pull cold air from outside. Those setups don't have that, and will actually suck hot air from the engine bay, reducing power. I'm not sure how the Prius's ECU would react to hotter intake air temperatures, either. And, the cone filters they use on those setups aren't the best at air filtration, meaning that they can cause engine damage.
    Leave the air intake tract alone, Toyota knew what they were doing.
  16. Scottyboy24
    33
    Pensacola, Fl.
    Man am I glad I ask you guys before I wasted my money and caused problems! Thanks a bunch for taking the time to educate me here!
  17. Scottyboy24
    33
    Pensacola, Fl.
    Oh, so you guys are also saying that the Toyota paper filter will seriously let more air through than say a K&N or AEM reusable filter will? K&N claims theirs lets a lot more air through to the engine.
    What I mean is since I am going to leave the oem system alone, could I still benefit from using a K&N instead of the oem Toyota filter?
    #17 Scottyboy24, Dec 27, 2016
  18. bhtooefr
    1,396
    1,489
    Newark, OH, USA
  19. Scottyboy24
    33
    Pensacola, Fl.
    Wow! I already learned about the oiling problem, I over oiled one on my 97 Vette and she bucked and died until i cleaned the maf. So I went to the dry after market filter by AEM. Because I thought it was helping my hp?
    But I never had it dyno'ed, so who knows? Maybe it is bs?
  20. Sam Spade
    2,036
    1,023
    2017 Prius c
    NO sorry, bad choices, BOTH.
    You can't just slap aftermarket "racing" parts on an engine and make it a racing engine.
    The ram air thing is more snake oil on a stock production car.....as is the K&N high-flow filter.
    Modern engines are very finely tuned to run right with ALL of the stock parts in place.
    Increasing the air flow IN will NOT give you better performance.
    Odds are that it will get worse if there is any change at all.
