Adding extra USB port
Discussion in 'Prime Accessories and Modifications' started by yoyoman, Dec 24, 2016.
  1. yoyoman
    yoyoman Active Member
    342
    117
    San Jose California
    I'm wondering if there is a way to add additional USB port for 1) USB drive for MP3 & 2) iPhone charging.
    Anyone recommendation?
    iPhone ?
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
  3. Insirt
    Insirt Junior Member
    60
    South Carolina
    The provided USB port's amperage is so low that my phone continues to discharge when plugged in so I'm just going to use an Anker dual-USB port 12-volt adapter where each port will have 2.4 amps.
    fuzzy1 and priuscatprimeguy like this.
  4. priuscatprimeguy
    2,730
    2,640
    true, that's how I charge my phone, but The USB port on the car doesn't it connect to the audio in the car? The 12 volt accessory outlet does not have that capability (I'm assuming)
  5. yoyoman
    342
    117
    San Jose California
    I'm aware that the 12v port will charge my phone but i thought we need to connect my iPhone thru the USB port in order to get entune function correctly.
    iPhone ?
    priuscatprimeguy and Insirt like this.
  6. Insirt
    60
    South Carolina
    Maybe try a usb splitter? I'm not sure if it's possible actually to have both connected directly at the same time...
  7. priuscatprimeguy
    2,730
    2,640
    that was my point:D
  8. yoyoman
    342
    117
    San Jose California
    If this is a true USB port, the splinter sb working.
    Has anyone try it?
    iPhone ?
  9. Civic4982
    Civic4982 Member
    46
    40
    Actually the support folks at Toyota keep telling me that to get entune to work correctly you're to connect with Bluetooth but not to the USB port as it doesn't know which is prioritized.
    It's odd.
    Anyways for that reason I use a cigarette lighter adapter for charging.
    iPhone ?
  10. fuzzy1
    10,409
    What about a common USB hub, 1-in 4-out? For best results, these may need external power (i.e. boosted from the 12V socket).
    I haven't tried this to check if my car's USB controller is smart enough.
    priuscatprimeguy likes this.
  11. MikeDee
    MikeDee Senior Member
    1,576
    596
    San Francisco Bay Area
    Just use one of those USB power plugs in the cigarette lighter port if all you want is power.
  12. Tideland Prius
    16,548
    The car will recognise up to two USB device via the USB port if you use a splitter. Any more, and it's just for charging.
    If it's for charging, a 12V-to-USB charger will work and it charges at a faster rate. (1A and 2A ports). If you need USB access, then use a USB splitter.
    Insirt likes this.
  13. Prodigyplace
    12,532
    11,754
    Central Virginia
    The Navigation manual does not say the USB post is able to charge an iPhone. If it is like the Gen 4 Prius, the power only meets USB specs, not phone charging.
    I did spot this warning in the manual, though.
    Civic4982 and priuscatprimeguy like this.
  14. Optimus PRIME
    Optimus PRIME Active Member
    180
    141
    SF Bay Area
    I would definitely use separate charger from the 12V cigarette port for USB charging, and use Bluetooth for connecting your phone to the vehicle for Entune.
  15. yoyoman
    342
    117
    San Jose California
    I have tried this last night without plugging my iPhone into the USB port. Seem like everything is working.
    iPhone ?
  16. jcburns
    jcburns Junior Member
    Atlanta
    We have a 3-USB to 12 volt adapter, and we moved it from the old car to the new one. We've connected (1 of our 2) iPhones to the system via Bluetooth and (although I was a Bluetooth skeptic) that's more than enough. Play audio, do phone calls, the works. One problem is that changing the volume or just selecting 'Bluetooth' from the Entune source menu plays the last music track on my iPhone whether I want it to or not (and no, I don't want it to.) Not sure if that's the iOS operating system's way or what.
  17. MikeDee
    1,576
    596
    What do you mean by get Entune to function correctly? My phone connects via Bluetooth for phone calls. I haven't tried it for music yet. I've got all my music on a USB stick. Sirius radio is good as well. I don't need to use the phone for music.
  18. yoyoman
    342
    117
    San Jose California
    If I remember correctly in my 14 prius, I need to plugin my iPhone to USB port in order to get entune traffic, and other search tool to function correctly. However, android phone doesn't need to plug in to work.
    iPhone ?
  19. MikeDee
    1,576
    596
    The Entune apps need your phone to work, so that can be via Bluetooth or USB. Traffic is over the air. (I think)
    iPhone ? Pro
  20. priuscatprimeguy
    2,730
    2,640
    nope, traffic is derived from the Entune app on your phone:D
