Charge mode
Discussion in 'Prime Main Forum (2017-2022)' started by park187, Dec 22, 2016.
  1. Mister MMT
    Mister MMT Active Member
    285
    142
    Germany
    Well, what some of us really would like to learn about is how much (at constant velocity), the mpg value diminishes when shifting from HV to charge mode.
    Jan :sneaky:
    JamesBurke likes this.
  2. jcburns
    jcburns Junior Member
    Atlanta
    Good question. Haven't tried that yet. But I will.
    Mister MMT likes this.
  3. MikeDee
    MikeDee Senior Member
    1,580
    597
    San Francisco Bay Area
    Huh? I wouldn't use charge mode going up a steep grade. All that will do is sap power from the engine and lower your gas mileage even more. Best to use it on the flats, preferably with a tail wind. I'll probably never use charge mode, I don't think.
  4. inferno
    inferno Senior Member
    1,072
    405
    But I believe Charge Mode saps a % of your MPG toward recharging the battery. I have this scenario so I can test either way. If Charge Mode saps a percentage and you're going up an incline, does 2-3 mpg matter as much versus on flats that might cause a 10 mpg drop or more?
    Also, perhaps going downhill in Charge Mode helps charge the battery faster? lol
  5. Mister MMT
    285
    142
    Germany
    Please find it out "empirically"! Thanks
    Jan
  6. bisco
    52,294
    it will likely sap a similar amount no matter what you're doing, but i also, am curious.
  7. MikeDee
    1,580
    597
    Using charge mode except possibly what John mentions above is going to lower your gas mileage.
  8. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Same thing as believing in a free lunch or perpetual motion.
  9. inferno
    1,072
    405
    Hmm, so you're saying Charge Mode is just a nicety and really doesn't matter? Excuse my ignorance in the matter.
  10. bisco
    52,294
    it is good for climbing really big mountains, or if you have a really important reason to drive ev, such as i have no idea. it's really close to useless in most circumstances.
    can you think of a time in your pip when you would have traded 10 mpg for more ev range?
    see the first page here arguments.:)
  11. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    you're only losing 10 MPG for about a half of an hour so if you're on a long trip more than a half an hour it makes sense besides how do you get 640 miles on 7 gallons of gas?
  12. bisco
    52,294
    7 gallons?(n) how are you going to get 640 miles on 7 gallons and an extra 25 miles of charge? sounds like 375 without force charge or 365 with force charge.
    priuscatprimeguy likes this.
  13. priuscatprimeguy
    2,730
    2,640
    Yup, that's assuming the low fuel indicator is beeping by then
  14. bisco
    52,294
    my calc is wrong, cause i figured 45 mpg for the whole trip, not half an hour. but even so, do we know it's 10 mpg? i think we only have rough estimates. what we do know is that it's less efficient to convert gasoline to electricity, than it is to use gas for power, due to conversion losses.
  15. priuscatprimeguy
    2,730
    2,640
  16. priuscatprimeguy
    2,730
    2,640
    When I tried it out my mpg read 47 mpg while it was charging then the final mpg for the round trip was 58 mpg
  17. priuscatprimeguy
    2,730
    2,640
  18. priuscatprimeguy
    2,730
    2,640
    It was Clawson Michigan to Howell Michigan and back 104 miles round trip
  19. bisco
    52,294
    does it get any better than that?:)
  20. priuscatprimeguy
    2,730
    2,640
