Prius 2010, Steering light is on and car is not driving even after resetting, pic attached
Discussion in 'Gen 3 Prius Technical Discussion' started by kiwii787, Dec 25, 2016.
  1. kiwii787
    kiwii787 New Member
    Auckland, New Zealand
    I just parked my type S 2010 prius on a slight slope and when i tried to start it started to give check lights, with ! sign on steering wheel sign,
    Tried resetting by taking off battery didnt work as it only gave bunch of check lights with same ! sign on the small steering wheel with all other check lights
    Dashboard image attached;
  2. scona
    scona Active Member
    225
    207
    Courtenay, BC, Canada
    2013 Prius v wagon
    The most often given response to a multi light problem such as you have experienced brings into question the 12volt battery. Has yours ever been replaced or is it the original one? If it is still on the first battery it is getting long in the tooth and probably should be replaced. See if Santa put one under the tree.......
  3. bisco
    52,124
    welcome! how many miles/km on her?
  4. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    Was your imported as a used car from Japan?
  5. b100
    b100 Member
    145
    75
    Netherlands
    Look at picture
  6. bisco
    52,124
  7. MeGuinness
    MeGuinness Member
    217
    78
    UK
  8. yoyoman
    yoyoman Active Member
    342
    117
    San Jose California
    This error message sound like a english but written in jap pronunciation.... like a "hybrid error check". Did u try to power up and power down your car multiple times?
    iPhone ?
  9. RRxing
    RRxing Senior Member
    2,549
    1,825
    NEPA
    The "!" next to the steering wheel light is part of the display, it does not necessarily indicate a problem with the steering. See attached for symbols. As mentioned, it could be a 12v battery issue. I'd start there. Good luck. Update us when you know anything...
