Prius Gen 3 HID Retrofit -- The Right Way. Lexus RX350 Bi-Xenon, German Osram, Denso
Discussion in 'Gen 3 Prius Accessories and Modifications' started by E46Prius, Aug 15, 2015.
  1. CaJoe
    CaJoe Junior Member
    Anyone around the Bay Area, CA and care to put this retrofit together for me? :)
    sfv41901 likes this.
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    U down for a road trip to SoCal?
    VS980 4G ?
    Dylan Doxey and CaJoe like this.
  3. CaJoe
    CaJoe Junior Member
    If you are serious I'll be down in SoCal in December. Gives me time to start piecing my parts together. I'll keep in touch!
    Dylan Doxey likes this.
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Serious as a heart attack
    I'll shoot u an pm with my contact info
    VS980 4G ?
  5. davidw8818
    davidw8818 Junior Member
    39
  6. Nopho4u
    Nopho4u Senior Member
    1,007
    2,061
    Socal son
    I imagine the RX-AFS would be a even easier install being that it isn't bi-xenon? Also would i even need to order a shroud cause it seems it the prius kinda already has one?
  7. Snow
    Snow Member
    91
    63
    Pewaukee, WI
    Not much more difficulty added to a bi-xenon projector. Only thing is an extra cable that connects to the high beam wire to trip the solenoid. You are also correct that you don't need a shroud.
  8. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
  9. Snow
    Snow Member
    91
    63
    Pewaukee, WI
  10. Nopho4u
    1,007
    2,061
    Socal son
  11. Nopho4u
    1,007
    2,061
    Socal son
    Anyone know if TRS is gonna have a new years sale?
  12. SubCode
    SubCode Senior Member
    739
    1,341
  13. Nopho4u
    1,007
    2,061
    Socal son
    I did. The plan to do a retro at this time was unplanned. Wish i knew
  14. Snow
    Snow Member
    91
    63
    Pewaukee, WI
    A thing to keep in mind if you go the Mini H1 route regarding the solenoid flipping up for the high beams is that sometimes they're known to stick. I have the 5.0 version and apparently there's a fix to do before installing, but I don't feel like taking apart my headlights anymore. Was really annoying because the beam would basically shoot straight to the ground until I pounded on the headlight so the plate flipped all the way back. Maybe they have this figured out in the 6.0 and or 7.0 versions though. I ended up just disconnecting the bi-xenon and only use the halogen high beams.
  15. Nopho4u
    1,007
    2,061
    Socal son
    I had h1 before in my previous car and that projector sucked. Going oem Lexus this time
  16. davidw8818
    39
  17. StarCaller
    StarCaller Senior Member
    1,274
    726
    Cedar Crest, NM, USA
    you're getting brand new ones for full price or you know of a source to get them cheaper?
    BION
    StarCaller
  18. Nopho4u
    1,007
    2,061
    Socal son
    Theretrofitsource.com
    2nd hand rx projector with clear lens
  19. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    80mm
    iPhone ?
  20. Greenteapri
    Greenteapri Active Member
    330
    387
    Cypress
    Is this, still, the easiest way to get decent HIDs?
