Single zone vs. Dual zone A/C
Discussion in 'Gen 4 Prius Main Forum' started by au_prius, Jan 2, 2017.
  1. Prodigyplace
    12,633
    11,809
    Central Virginia
    I think I just have vents under the front seats facing rearward.
    alanclarkeau likes this.
  2. Prodigyplace
    12,633
    11,809
    Central Virginia
    Do you think the gauges in the Corolla Hybrid would work for @Bill the Engineer on his Prius v based Firebrid project? The original Firebird had round gauges. He tries a Lexus hybrid gauge but could not interface it with the Prius v.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I guess it's possible - the other possibility is the RAV 4 Hybrid you get in USA (not here).
    Bill the Engineer likes this.
  4. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    I'll look into it! Anybody have the part number of that Corolla Multi-function Display shown in the earlier post?
    Bill the Engineer
  5. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    UK gets the RAV 4 hybrid as well. Test drove one about ≤10 miles and found it really nice. Thought about placing an order to replace CRV, but changed my mind back to Prius. The shall I, shan't I dilemma only lasted for a day!
  6. alanclarkeau
    7,045
    7,593
    Not sure - it's only just been released here - but I think it has been in Europe for a number of years (called something like Auriz?). But you might get a RAV 4 part from the Wreckers seeing they've been in USA for a number of years and has sold well I understand. You have a larger SUV hybrid too, I think.
  7. Tideland Prius
    16,604
    True. The Prius is the first Toyota with automatic S-Flow. I suppose other Lexus models that have S-Flow require the driver to select the mode.
  8. Kama
    Kama New Member
    Australia
    2015 Prius v wagon
    I have 2014 3rd Gen prius itech that have single AC Zone. All comming from Japan. I wish it had sexond and third row cooling too.
    LG-D855 using PriusChat mobile app
  9. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    I always wondered if someone might try using the Scion IM dual climate module in their prius what might happen. Here are the backs out of the two, the one below is the Scion IM 16 module im.jpg
  10. robsnyder20
    378
    302
    SW Florida USA
    s-l1600 (1).jpg From the Gen 4 Prius: It appears from the above pictures one might be able to swap out the snap on exterior between the two. I'm not really interested in taking apart my dash but might have to do this swap if it works for someone else.
  11. Prodigyplace
    12,633
    11,809
    Central Virginia
    Why do you think they would be compatible? Because they both have an RJ45 connector?
    Does that mean you could plug in a network switch or PC and expect it to work? :eek: I seriously doubt it.
  12. robsnyder20
    378
    302
    SW Florida USA
    Aren't they both built using the TGNA architecture? You might be correct, they may look similar but might be built totally differently as far as programming is concerned.
  13. Prodigyplace
    12,633
    11,809
    Central Virginia
    The Gen 4 Prius was the first TNGA car so the iM is not TGNA, at least not yet.
    I thought TGNA was mainly chassis, not electronics.
  14. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    I doubt that that panel would work correctly, given that the functions aren't identical.
    Prodigyplace and alanclarkeau like this.
  15. djSyndrome
    djSyndrome Member
    30
    27
    Seattle-ish
    TNGA is just a platform. The iM is essentially an E180 Auris, which is now five years old. I would expect the next Auris, like most FWD-based Toyotas, to migrate to TNGA.
    RCO likes this.
  16. alanclarkeau
    7,045
    7,593
    I'd suspect that if you put the other module in, the computer would say something polite like "Pardon Me, that's not mine".
    Though, Computers tend to have their own terminology - "MALFUNCTION - WHOLE CAR".
    RCO likes this.
  17. booke02
    booke02 Active Member
    391
    415
    Israel
    I find this thread rather interesting. Are you looking for dual-zone A/C in your 2016 Prius? This is a standard feature in the model that is supplied in this country. Note the bottom right-hand button on the A/C control unit.
    So the option does exist for the Prius.
    Prodigyplace likes this.
  18. Prodigyplace
    12,633
    11,809
    Central Virginia
    The US cars may not have the correct software for that. Is your car left-hand drive or right-hand drive? It would be interesting if somebody could get the part from a wrecked Prius to try in the US. I would test on a Three or Four first since we know the Two & Two Eco only have the basic Entune system.
    RCO likes this.
  19. yeldogt
    yeldogt Active Member
    810
    313
    NE
    More is not better -- would be interesting to know what the savings are with this new system vs the gen3. All of my cars have had climate control for the past 30 years -- the only ones that have been annoying are the multi position ones. All the Lexus come with them -- in larger cars they don't matter as much .. but in small cars the other outlets are too close and too little air to heat/cool
    At least the Denso units have proven to be trouble free -- can't say the same for the german systems.
    RCO likes this.
  20. booke02
    391
    415
    Israel
    Left-hand drive.
